Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 01-08-2005, 06:55 PM   #1 (permalink)
Default Monitor went blank (Urgent)
Hi there . I recently bought your JULY issue and installed a game from it. After succesfully installing the game it asked me whether i'd like to view the game in a full screen mode and it also said that not all PC's have this feature(Full Screen mode) in them. I opted for yes and my monitor went blank. There seems to be no major problem with the system as you can still here the startup sound(Desktop theme) going on in the background. I tried rewiring the whole thing several times but the problem is still there. Could you mail me the solution to this problem on my id i.e. rahul_3250@yahoo.co.in
THANKS.[/list][/code]
rahul_2350 is offline
Old 01-08-2005, 08:08 PM   #2 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
can u view ur screen before the windows loads....
If u can then boot into safe mode and then try changing the full screen to window....( do this if it provides an external config ..) If u cant try uninstalling the game and reinstalling the video drivers...
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 01-08-2005, 09:33 PM   #3 (permalink)
Jai Suresh
lywyre's Avatar
restart ur system in VGA (Win XP) mode or safe mode (Win 98) and change ur resolution. that should fix the problem.
To go into bootmenu:
Win98: Press F8 while booting
WinXP: Press and hold CTRL key while booting
lywyre is online now
Old 01-08-2005, 09:42 PM   #4 (permalink)
Default Re: Monitor went blank (Urgent)
Can't you post a screenshot?
It will be easy for others to solve the issue if u had provided a screenshot.
Mahesh Babu is offline
Old 01-08-2005, 11:15 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
@rahul_2350
wellcome to the forum...
our July issue??
lol... man... most of us dont work in digit... dont work in digit MAG....
well for ur probelm... post ur system config... & do u use LCD monitor??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-08-2005, 09:07 AM   #6 (permalink)
MVP in VC++
This is probably because the game has set the high resoultion for the monitor which the monitor does not support....
so restart the system and in the safe mode...which u will get by pressing F8......change the resoultion or try with diff settings.
cvvikram is offline
- by kool
