By setting up a wi-fi network will you be sharing a internet connection ir is it just for sharing network resources across wired & wireless hosts ?
Depending upon that you need wi-fi network adapters for each host,PCI or USB or PCMCIA cards for laptops, a access point for connecting wired & wireless devices together or a wireless router.
All of the above equipment is not needed,it would depend on what you want to achieve.So tell us your requirements & we will be able to tell you more.
Anyways here is add Linksys costs too which I'm buying in the first week of august.
1.Linksys WRT 54G 802.11g wireless router- 3.4k + tax
2.Linksys PCI 802.11g wireless network adapetrs-2.1k each + tax
www.Oobertech.net
