Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 04-06-2009, 08:15 PM   #31 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: How to: Connect 2 PC's (in same room) for LAN gaming, Internet & Data Transfer
It is again on Ebay for special Deal
http://cgi.ebay.in/ws/eBayISAPI.dll?...m=130309495981
Price : 1,549.00
Less : 159 (10% discount coupon B0KKRYAGTA
Price : 1390
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 04-06-2009, 10:49 PM   #32 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
thanx for the info... but are u advertising that product here is it.. ?? Lol.. (looking at the Discount coupon code..lol..) jus joking..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 05-06-2009, 06:31 AM   #33 (permalink)
ICE COOOOL!!!
IronCruz's Avatar
Even i want to get connected with my freind through LAN. But the distance
b\n. mine and his home is <1km. Both of us have DNA A211 1 Router/Modem.
Can we get connected.........
IronCruz is offline
Old 05-06-2009, 06:39 AM   #34 (permalink)
Host4Cheap.org
Yes, you create a VPN using Himachi but it will be damn slow
Old 05-06-2009, 06:41 AM   #35 (permalink)
Host4Cheap.org
Nah! it was ebay front page so i saw it and thought of posting so interested people can advantage. It usually sells at 1800 so there is Rs 400 advantage
Old 05-06-2009, 12:09 PM   #36 (permalink)
Aah.. got the point,, thanx. .will look at tat offer at ebay.in ...
btw. its hamachi and NOT himachi..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 17-06-2009, 12:22 AM   #37 (permalink)
ok guys, so today i bought the DLINK DIR300 (wireless router) having 4port+wifi connectivity..
now im having trouble configuring it, as i already have DLINK ADSL Router (DSL 502T) with wich my MTNL Triband (broadband) is provided.. now plz tell me how to set this DIR300
this is wat i did:
1.) Installed the DLink LAN card onto the pci slot of my mobo, installed the drivers.
2.) ALso installed the DLINK Wireless router DIR-300 along with its drivers.
(both were easily detected by my OS: Win XP PRO+SP3)
3.) Now, the ADSL (telephone) line (from MTNL triband) wich is coming from the splitter is going at the back of the DLINK ROUTER DSL 502-T (this is my existing wired router)
4.) One RJ45 cable is goin from the "ETHERNET" jack (from the back) of DSL 502T (my existing wired router) to the "INTERNET" jack (at the back) of DIR-300 (my new wireless router)
5.) Another RJ45 cable from the "LAN" port jack of DIR-300 (wireless router) is goin into my D-Link LAN card of my PC.
<<--RJ45 cable from LAN card of PC-->>........going to......... <<--LAN port of DLINK Wireless Router (DIR 300)-->>..........now........ <<-- RJ45 cable from "INTERNET" port of DIR-300 -->> ........going to........ <<--"ETHERNET" port of my exisiting DLINK Wired Router (DSL 502-T)-->> .......now........ <<-- ADSL wire (telephone line) from "ADSL" port of DLINK Wired Router (DSL 502 T) -->>........going to........ <<-- Splitter -->>
Now, the address of my existing wired router... DLINK DSL 502T are as follows:
a.) IP Address: 192.1xx.1.1XX
b.) Subnet mask: 255.255.255.0
and the address of my new wireless router...DLINK DIR-300 are:
c.) IP Address: 192.1xx.1.1XY
d.) Subnet mask: 255.255.255.0
But, still i cant connect to the net (after ofcourse) enabling both the routers i knw im either wrong in the physical connection part or in the address part, so plz help me
I bought this new wireless router to basically connect my 2 PC's in LAN but jus now for the sake of it, jus testing the wireless router (DIR-300) as well as the wired router (DSL 502 T) only on ONE PC
--------------Plz Note: My existing Router (b4 buying this new D link Wireless Router DIR-300 and D link LAN Card) was connected to my PC via USB connection...
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 17-06-2009, 12:25 AM   #38 (permalink)
Also, how can i setup the wifi security codes of say WEP, WPA (TKIP), WPA2 (AEK) etc..etc.. and watever else is required to secure my wifi also, how ca
as this is my 1st time with wireless stuff, im jus a noob but i do knw tat securing my wifi is really important..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 17-06-2009, 10:23 PM   #39 (permalink)
Fast 'N' Furious
topgear's Avatar
Take a look @ these threads
Reference Guide on How to Share DataOne Connection....
setup a home wifi-lan, share internet connection
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 18-06-2009, 06:38 PM   #40 (permalink)
Host4Cheap.org
@ashu888ashu888 : You dont need so much stuff to be done IMHO.
1. You connected the hardware in right fashion As far as i can see
2. Pop in the Dlink Install CD. It should have easy install GUIDE or something to get you ready with self troubleshoot. I am not sure but this is case mostly
3. There should be some way to access ROUTER settings for WEP etc. Like in Netgear : you login via www.routerlogin.com
Old 19-06-2009, 09:17 AM   #41 (permalink)
thanx alot topgear, much appreciated once again as always dude.. will read into that for more understanding..
Thanx for ur reply Sukhdeep
I jus forgot to "Configure the Wireless Router" by goin to 192.168.0.1 and was able to setup a connection using DHCP (Dynamic IP) method,
but the problem i sumtimes get is that, a connection is lost b/w my Wired (DSL 502-T) and my wireless router (DIR-300) I dont knw how or y, maybe a faulty DSL 502-T ... but can there be any other reasons.. ??
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
- by kool
