Go Back   Digit Technology Discussion Forum > Internet and Networking > Networking
Networking Setting up network connections, issues related to hardware, buying advice related to routers, modems etc. should be posted here.
Old 20-05-2005, 01:25 PM   #1 (permalink)
Default Problem with installing 2 LAN cards
I have an internet connection that I access thorugh a LAN card. I added a second LAN card to transfer files from a laptop. Now I can't access the internet through either card. If I remove the second card, the net works fine. Please tell me how I can have 2 LAN cards in my system without the internet access being disrupted.
drvarunmehta is offline
Old 20-05-2005, 01:54 PM   #2 (permalink)
The less technical answer would be to use the lan card for the internet connection to transfer data from the laptop.
The problem could be with the IP settings.What are the IPs for the cards?
Please do not PM me for details about the product. Ask the questions in the forum itself.
Shipping outside Kerala is a hassle.
Ref : http://thinkdigit.com/forum/showpost.php?p=820996&postcount=53
htnakirs is offline
Old 20-05-2005, 02:06 PM   #3 (permalink)
The IP's for the cards are totally different.
Old 21-05-2005, 12:54 AM   #4 (permalink)
i have a system that works with four lan cards ( as a router, firewall) so no problems just set the ip to fall in diffrent subnets and configure the default GW to be the IP where the net is connected every thing will work.
**** happens
pradeep_chauhan is offline
Old 21-05-2005, 03:36 AM   #5 (permalink)
144
144's Avatar
which OS are you using?
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
- by kool
