Hey i own a N82..& to save battery life..do the following:
1) Turn-off icon animation
2) Turn-off Wi-Fi/Bluetooth
3) Use less time 4 power-saver such as 10-15secs also same for light-off mode...
4) Use GSM mode & not Dual-MOde in network connections
5) Use Nokia's Default themes & not the 3rd party themes
6) Put the screen brightness 2 low...
7) Turn-off the preview of clicked-images or videos
8. Turn-off flash while taking pictures in full-daylight
9) Use the multimedia key(it is in N82) 2 access music,pictures,videos,n-gage etc.
Remember: the more no-times u press the keypads the more ur battery will drain
Originally Posted by krazzy
This feature was there since Nokia 7610. Earlier you had to press and hold the Menu key to access the Task manager. In the FP2 the procedure is the same, but now you only see the icons without their names in a grid view. They've also added the short cut to Task manager in the options menu. That's to make sure that people will be using it more often.
Hahahahahahahehehe
