Old 09-10-2008, 05:32 PM   #1 (permalink)
CBZ is better than Pulsar
panacea_amc's Avatar
Cool Screen capture proggy for Java mobile fones!!!
here is an applet that can capture the screen of ur Java enabled handset...there are many such proggys for Symbian fones but, i believe this is the first one for Java fones like Sony Ericcson...u have to run this proggy in the pc and connect ur mobile thru the data cable and then u can have ur capture working!
the applet is attached here and please give ur comments...
|| Beauty is to the Mind what Food is to the Body ||
panacea_amc is offline
Old 09-10-2008, 05:46 PM   #2 (permalink)
TECHNOHOLIC..............
nitansh's Avatar
Default Re: Screen capture proggy for Java mobile fones!!!
Thank you very much for this wonderful application.... It works like a charm...
"You go to your TV set when you want to turn your brain off. You go to your computer when you want to turn your brain on." - STEVE JOBS
nitansh is offline
Old 09-10-2008, 08:18 PM   #3 (permalink)
thanks!
More, more feedback i want!
Old 09-10-2008, 09:13 PM   #4 (permalink)
Here Since 2003
Indyan's Avatar
Nice work.
Btw, SE users can get this funtionality via ELF's if they are ready to flash their firmware and fs and install custpack and elfpack.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Cool softwares 4 JAVA fones! panacea_amc Mobiles and Tablets 62 01-08-2008 08:12 AM
Download manager for JAVA fones! panacea_amc Mobiles and Tablets 8 02-07-2008 11:48 PM
best screen capture software bukaida Software Q&A 5 23-10-2007 03:42 PM
Which is the best screen capture utility?? shady_inc Software Q&A 26 06-09-2007 12:15 PM
screen capture ishaan QnA (read only) 5 22-11-2005 04:30 PM
- by soumya
