Old 07-10-2008, 03:23 PM   #1 (permalink)
Time To Play The Game
Arrow Help in selecting Nokia N95 vs. N95 8Gb
HELP
With Pros and Cons. Also I need suggestions from old n95 and n95 8gb users
thanks in advance
bilal
bilalarc is offline
Old 07-10-2008, 04:07 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Help in selecting Nokia N95 vs. N95 8Gb
N95 Pros
Lens cover
Memory card slot
More spacious navigation keys
Cheaper
Cons
Low capacity battery
Low RAM
N95 8gb Pros
Bigger, brighter display
Louder speakers
Built-in 8gb memory
Bigger battery and RAM
Cons
No lens cover
Memory cannot be expanded over 8gb
Navigation keys smaller compared to N95.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 07-10-2008, 04:54 PM   #3 (permalink)
R2K
In the Zone
R2K's Avatar
IMO N95 is really bulky....why do u want to go for this phone
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is online now
Old 08-10-2008, 12:50 PM   #4 (permalink)
As a nokia n81 previous owner,
I miss some things in my n81 like
dual slide design
accelerato meter
3d GFX chip
So, any more suggestions...
bilal
bilalarc is offline
Old 08-10-2008, 01:25 PM   #5 (permalink)
moshel's Avatar
N95 8gb has accelerometer.....the other one does not.
moshel is offline
Old 08-10-2008, 01:46 PM   #6 (permalink)
Power UP's Avatar
The classic one also has it.
Power UP is offline
Old 08-10-2008, 02:05 PM   #7 (permalink)
Sing Along Samsung
Tanmay Satpathy's Avatar
go for N95-8gb. It has more RAM which results in better performance and lesser hangs. Big screen and a cool black color. However if you don't consider dual slide design (a bit of uncomfortable in jeans pockets) N82 is slight better option.
In my opinion go for a set with S60 3rd edition FP 2 (newer models of nokia features this os).
Win 7 and any mobile suits my MOOD
Tanmay Satpathy is offline
Old 08-10-2008, 05:05 PM   #8 (permalink)
moshel's Avatar
Originally Posted by Power UP View Post
no it does not....http://www.gsmarena.com/nokia_n95-1716.php
moshel is offline
Old 08-10-2008, 06:06 PM   #9 (permalink)
Techans
nikhilpai's Avatar
Its available with the latest firmware update V30
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
nikhilpai is offline
Old 08-10-2008, 06:39 PM   #10 (permalink)
Power UP's Avatar
It had the accelerometer from the beginning itself.
It was not enabled in the initial firmware but enabled in v30.0.015
Here is an video http://www.youtube.com/watch?v=26duMakivPE
The device details on gsmarena is only stating the launch spec.
Power UP is offline
Old 08-10-2008, 11:32 PM   #11 (permalink)
I ve been using the n95 8 gb for some time now and frankly although the phone has everything i particularly do not like it.Its rather bulky and the inteface is just like any other nokia phone.Spend your money somewhere else.
bigron is offline
Old 09-10-2008, 01:25 PM   #12 (permalink)
All right
this is what i am aiming for
get a n95 or n95-8gb
OR
go for a pc upgrade
1. E8400
2. Nvidia 9800 GT or ATi 4850
so Help coz I am confused what to do.
bilalarc is offline
Old 09-10-2008, 04:40 PM   #13 (permalink)
R2K
In the Zone
R2K's Avatar
go for the PC upgrade ..........N95 is not worth for that kinda money
R2K is online now
Old 09-10-2008, 07:29 PM   #14 (permalink)
Upgrade ur pc.
Oh $hit!
Head Banger is offline
Old 09-10-2008, 09:02 PM   #15 (permalink)
moshel's Avatar
it depends on 2 things..
1. what PC ur having right now.
2. what phone ur using right now.
if both of them suck then try to invest in both the things...
If u can live with your current PC or Phone right now, then go for the other remaining thing.
moshel is offline
Old 10-10-2008, 12:25 PM   #16 (permalink)
Currently I hav N81 2gb mobile
as for pc
these are my spec
Intel Pentium D (Dual Core) 3.00 GHz With Ring Heatsink Fan Cooler
Intel D 945
2 X 1Gb Kingston DDR2 RAM @ 667Mhz
Nvidia 7600 Gt 512 mb stock cooler.
400w local PSU
LG Optical Combo drive CD/CD-R/CD-RW/DVD
2 X HD 160 Gb SeaGate 7500RPM
Apocalpyse X400 MOD Case with 2 Aftermarket Fans
Windows Xp Pro SP2 Genuine Validated.
Now I see both them old.
help?
bilalarc is offline
Old 10-10-2008, 05:48 PM   #17 (permalink)
well, in ma openion u shld go for pc upgrade..
c2d E4600, asus p5kpl-cm, 2x1gb transcend ddr2 800, aoc913fw, seagate 250gb sata2..
ayush002 is offline
Old 10-10-2008, 08:38 PM   #18 (permalink)
OK
but First I hav another question to N95 8gb owners
Does your n95 8gb slide runs loose or stay good all long?
bilalarc is offline
Old 10-10-2008, 09:36 PM   #19 (permalink)
sam_1710's Avatar
welll the build quality of the n95 8gb is too bad... The slider starts to wobble slightly, but doesn't "run loose"
The paint on the volume, camera and gallery keys gradually peel off..
sam_1710 is offline
Old 10-10-2008, 09:55 PM   #20 (permalink)
moshel's Avatar
yeah go for pc upgrade...i dont suppose N81-N95 would make u have a ground breakingly new experience as much as upgrading ur pc will.
moshel is offline
Old 11-10-2008, 02:58 PM   #21 (permalink)
There is ovast diffefence between n95 and n95 8Gb. the difference is only of memory. N95 8GB becomes sluggish. I think among these n82 is better.
Give the best, Give up the rest
choicefreedom2000 is offline
Old 11-10-2008, 04:11 PM   #22 (permalink)
Thumbs up Re: Help in selecting Nokia N95 vs. N95 8Gb
I hav heard that the new firmware v20-v30 removes many halt sluggish bug from n95 8gb, and makes it more stable.
Reason I asked the question is that my n81's front navi wheel starts to rip of the silver paint from a side, and some scratches on the back cover. Thats why i wanted to know more info what to do. friend of mine told me to get a new mobile, as I prefer slider design so N95 8gb get into my eyes.
Question for N95 8gb owners,
1. Does your mobile reboots what the v30 firmware update, is it more speedy, stable?
2. How many month use makes the slider wobble?
SECOND NEWS
I am also going for the pc upgrade !!!!!!!!! HOOHAAAY
But I have a question:
1.If I install the following items in my pc whats the most bottleneck part in
the specs left?
a. E8400
b. Nvidia 9800 GT or ATi 4850 ( depends on my area availability )
SPECS:
Intel D 945 GCNL MOBO
400w local PSU
PLZ help again.........
thanks
bilal
bilalarc is offline
Old 11-10-2008, 08:38 PM   #23 (permalink)
moshel's Avatar
Originally Posted by bilalarc View Post
SECOND NEWS
Congratulations
the specs left?
a. E8400
SPECS:
400w local PSU
thanks
bilal
change ur mobo, if u want something cheaper then go for the Abit IP35-E...or any mobo u choose based on P35 chipset.
I dont think the 400w PSU will be able to handle a 9800GT.
moshel is offline
Old 11-10-2008, 09:08 PM   #24 (permalink)
yogi7272's Avatar
even with ver 20 firmware, my n95 8gb was very fast with no rebooting issues .. with ver 30 the situation is improved a bit ..its a bit faster now .. and the slider does wobble a tiny little bit ..not a huge drawback ..i am just using it for the last 20 days so, long term effect is not known ..
yogi7272 is offline
Old 13-10-2008, 01:21 PM   #25 (permalink)
Ok thanks alot everyone.
now I am planning to get n95 8gb this week and pc upgrade next month.
Can anyone give me a list of good performing mobos p35 and p45 in a list so that I could search for one of them.
NOTE:- 1.In my area abit mobos are not available.
2.Intel, Asus, Msi, Nvidia, Gigabyte mobos are alomost available.
thanks again
bilal
bilalarc is offline
Old 17-10-2008, 11:45 AM   #26 (permalink)
gdatuk's Avatar
good choice.. am a happy owner of N95 8gig... but for the lack of camera lens cover
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 20-10-2008, 06:00 PM   #27 (permalink)
This is up to you what do you want to use in your mobile phones both are similar except memory .If you are looking for more capacity of memory then n95 8GB is better but there is no card slot while in n95 there is expandable memory. I think both are alike. just browse http://www.blueunplugged.com/c.aspx?c=39978 and see which one to be owned?
Need Help with selecting config for my rig rahulyd PC Components / Configurations 7 25-11-2007 07:07 PM
need help in selecting h/w jackal_79 Hardware Q&A 1 05-09-2007 12:56 AM
Help me in selecting SMPS N@LiM Hardware Q&A 5 07-02-2007 02:52 PM
Selecting OS... rthegr81 Software Q&A 3 27-06-2006 02:24 PM
- by soumya
