Old 27-09-2008, 08:08 AM   #1 (permalink)
Default Phone for camera and PC net browsing under 5k
I need a phone to take some pics and mainly to be able to browse net in my laptop. so EDGE may be needed.
dont need an mp3 support in mobile as i have an mp3 player.
camera in mobile need not be Hi-fi as i have a digital camera...though i wont be carrying it around all the time...so need a mobile with a camera that can help me take pics in urgent situations...1.3 MP is enough..
Suggest me the cheapest mobile i can get under these conditions...
PS: i have a 256 mb and 1 GB sd card with me now...so please suggest a phone that supports this...
sarkar_reloaded is offline
Old 27-09-2008, 08:16 AM   #2 (permalink)
AJJU
azzu's Avatar
Default Re: Phone for camera and PC net browsing under 5k
Nokia 3110 c
Nokia 3500
I love and Live to Design
azzu is offline
Old 27-09-2008, 08:42 AM   #3 (permalink)
Thanks....Which among these is having the better camera...?
what abt moto rizr z3?
slider phone with 2 mp camera , edge , bt etc.
costs only 5k!! Will these act as a modem for PC..?
will z3's camera be as good as 3500/ better than 3110c?
Last edited by sarkar_reloaded; 27-09-2008 at 08:53 AM. Reason: Automerged Doublepost
Old 27-09-2008, 09:24 AM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
If you can get Z3 in 5k then go for it. It is better then either 3110c or 3500c. And yes it can act as a modem.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 27-09-2008, 04:31 PM   #5 (permalink)
Ok...Y it is better than 3110 and 3500..?
any more advice are welcome ?...
Old 27-09-2008, 06:08 PM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
It has higher resolution display, better display and better looks.
Prasad Naik
krazzy is offline
Old 29-09-2008, 08:10 PM   #7 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
Man; I dont think we get RIZR Z3 in 5k? do we?
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 29-09-2008, 08:17 PM   #8 (permalink)
geek........
Gauravs90's Avatar
Nokia 5200 is best if used as modem.
It supports EDGE
Bluetooth speed 60 to 80 kbps
with my idea connection it gives maximum of 21 kbps.
Gauravs90 is offline
Old 30-09-2008, 05:43 PM   #9 (permalink)
if you rae looking for camera among both I let you know that Nokia 3500 is equipped with 2mp camera and 3110 with 1.3mp.
Give the best, Give up the rest
choicefreedom2000 is offline
Old 30-09-2008, 08:29 PM   #10 (permalink)
I'm Back!:D
Coool's Avatar
go for Z3.
2mp camera with flash,
beautyful design,
1.9" display,
higher resolution [176 x 220].
Coool is offline
Old 01-10-2008, 12:40 AM   #11 (permalink)
^^ I just dont believe we get it for 5k.. Damn good VFM.
AOC Fovi F22
Old 01-10-2008, 11:40 AM   #12 (permalink)
India rocks
amc888's Avatar
Yes, Z3 costs 5K. Check this http://www.univercell.in/component/page,shop.product_details/flypage,shop.flypage/product_id,199/category_id,6/manufacturer_id,0/option,com_virtuemart/Itemid,28/
amc888 is offline
Old 01-10-2008, 08:51 PM   #13 (permalink)
though my bro's tochscreen motorockr went nuts and i am deciding agisnt it...
yeah u get it there for univercell
Old 06-10-2008, 09:10 AM   #14 (permalink)
BTW will a class 12 gprs make a big difference to internet speed using mobile...
Old 06-10-2008, 09:27 AM   #15 (permalink)
Techtree Reviewer
krazzy's Avatar
That depends upon the service provider. But I don't think the difference between Class10 and Class 12 will be much. Class 32 on the other hand offers substantially higher speeds.
Prasad Naik
krazzy is offline
Old 24-11-2008, 01:57 PM   #16 (permalink)
99.9% Idle
axxo's Avatar
can anyone confirm me of its price and availability, any other source other than univercell? I want to buy this mobile if its available for 5k.
Unban praka123
axxo is offline
I Need a Phone WITHOUT CAMERA Games Goblin Mobiles and Tablets 33 16-08-2008 11:59 AM
which is the best camera phone Baker Mobiles and Tablets 20 13-12-2007 07:55 AM
Nokia Camera Phone as WEB Camera skghosh44 Mobiles and Tablets 5 27-07-2007 07:06 PM
Browsing net with phone abhi_shake Mobiles and Tablets 15 22-10-2006 01:14 PM
best camera phone?? anispace Cameras and camcorders 7 21-01-2005 11:33 AM
- by soumya
