Old 25-09-2008, 10:16 AM   #1 (permalink)
AJJU
azzu's Avatar
Angry SE Application Error <HELP ME>
I hav been using Se k790i Frm last 7 months so.. and didnt faced any problem but frm last two months When i tried to Open my Applications In the Organizer it Says "OPERATION FAILED" so do with the GAMES then i tried to open the application and games folder from the file manager and the same problem.I transferred a Application from my computer to another and the App isnt opening giving the same problem . I hav Master restted the fone thrice and i tried to update it via SEUS but it says ur firmware is up to date
Plz help me iam a daily user of opera mini so iam connected to the net on go...
iam facing a lotta problem not
The Se service centre is up to 160kms away from my home town so plz help me solve my problem
I love and Live to Design
azzu is offline
Old 25-09-2008, 11:08 AM   #2 (permalink)
Rockin g33k
dreamcatcher's Avatar
Default Re: SE Application Error <HELP ME>
Just reflash your phone through SEUS or XS++.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 25-09-2008, 11:21 AM   #3 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Before going that extreme.. Try connecting it to pc using usb. . And check for errors.. Then restart the phone..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 25-09-2008, 07:15 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Check for errors? By what? you dont exactly run CCleaner on Sony firmware, do you? The only thing is reflashing main, and its not extreme at all, just a 5 minute job.
dheeraj_kumar is offline
Old 25-09-2008, 11:00 PM   #5 (permalink)
It doesn't matter!
Hey.. If u cudn't understand ask, i'll type as detailed as possible,again..
Don't ever pick on me.. I've experience similar to this..
@azzu
I guess the apps in phone memory are working..
If so,try what i've mentioned in earlier post... And by check for error on the memory card using disk scan/check utility of windows...
Old 26-09-2008, 08:35 AM   #6 (permalink)
AJJU
azzu's Avatar
No they Aint did that bfore
i think Reflashing doies help now
Now how do i do it with SEUS when i tried to update it says ur fone is up to date and theres no other option
Now i hav the XS++ where can i get the Firmware which is R1JG001
i cant get it and i dont know anything about flshin i havent did it Bfore Plz HELP
Elp
Plz help me ..
azzu is offline
hpdj00.exe application error vasulic QnA (read only) 2 25-11-2006 10:22 AM
application error smj Software Q&A 1 21-09-2006 06:45 PM
SOS - Application Error! Kerry QnA (read only) 5 27-01-2006 11:22 AM
application error help? bhavi_panchal Software Q&A 6 25-10-2005 10:42 PM
REQ:EXPLORER.EXE-APPLICATION ERROR aadhar Software Q&A 6 30-12-2004 12:15 AM
- by soumya
