Old 18-09-2008, 11:52 PM   #1 (permalink)
mohitgiri's Avatar
Default roker e8 help
i have roker e8.
i have 1 gb memory card in it. but the device show that this is the invalid card. do u want to format it---->> YEs--->> formatting failed.
also not showing in pc.
plz help
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 19-09-2008, 09:07 AM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: roker e8 help
Was the card from a good company like SanDisk or Kingston or one of those cheap ones?
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 19-09-2008, 12:51 PM   #3 (permalink)
mohitgiri's Avatar
yuup...
it is ORIGNAL NOKIA card
MOHIT GIRI GOSWAMI
Old 19-09-2008, 01:02 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Try this:
Connect it to PC. Open disc manager (start -> control panel -> computer mgmt -> disc mgmt)
Sometimes, when there is no partition allocated or fat table is corrupted, you will not be able to use the card.
recreate partition on the card and see if it works.
desiibond is offline
Old 19-09-2008, 01:37 PM   #5 (permalink)
mohitgiri's Avatar
i have change the card now its workin. but...........
how can i transffer the files inti card. pc is just showing the drive A of phone memory.
MOHIT GIRI GOSWAMI
Old 19-09-2008, 01:49 PM   #6 (permalink)
Techtree Reviewer
krazzy's Avatar
Try the card in some other phone or a card reader. Then try and format it.
Prasad Naik
krazzy is offline
Old 19-09-2008, 05:06 PM   #7 (permalink)
Juke Box Hero
Also ensure it is set to Mass Storage mode. Main Menu > Settings > Connections > USB > Memory Card.
Hitboxx is offline
Old 19-09-2008, 06:42 PM   #8 (permalink)
mohitgiri's Avatar
Yaaah......
Now Its Workin Fine. Thanx For Help Guys..
Regds
MOHIT GIRI GOSWAMI
want to run net on pc wid moto roker e6 mohitgiri Mobiles and Tablets 2 18-06-2008 11:04 AM
- by soumya
