Old 09-09-2008, 03:44 PM   #1 (permalink)
channabasanna's Avatar
Default Phone Switches Off Automatically
Hi All,
Recently my mobile (N73ME) gets switched off when i recieve a call, or so. The mobile wont be low on Battery when it gets switched off. What may be the reason for this to happen. What is the solution for this.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 09-09-2008, 05:10 PM   #2 (permalink)
Default Re: Phone Switches Off Automatically
May be due to a virus...hard format your phone and update its software
sushantvirdi is offline
Old 09-09-2008, 05:14 PM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
A virus in N73 is unlikely. It probably needs a firmware upgrade (if it is using an older version) or needs to be formatted.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 09-09-2008, 09:41 PM   #4 (permalink)
I updated my mobile to V4.0812.4.2.1 version just now. So will see if that problem persists. That was happening rarely. I mean once in a month or so.
Old 09-09-2008, 09:43 PM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
^^^ any call record software sort of something you are using ?
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 09-09-2008, 11:17 PM   #6 (permalink)
No i am not using any such software. I was using full screen caller, but never enabled that much. I feel it is not because of that full screen caller.
Old 10-09-2008, 06:53 AM   #7 (permalink)
krates's Avatar
^^^ well just uninstall it and then try
these call softwares may be the only problem i suppose
just don't use it even it takes very much ram
these types of software are crap
krates is offline
Old 10-09-2008, 10:58 AM   #8 (permalink)
Now i am not using any such softwares, infact the mobile switched off yesterdar, i had uninstalled that full screen caller last sunday itself. Also the RAM used is only 13MB, and showa 31MB Free. Did u mean Phone Memory as RAM.
Also in the new update i did yesterday, there is a new application Mobile TV, how to use that. Have anyone tried using it.
If so do help me in how to use that.
Last edited by channabasanna; 10-09-2008 at 11:00 AM. Reason: Automerged Doublepost
Old 11-09-2008, 05:20 PM   #9 (permalink)
R2K
In the Zone
R2K's Avatar
what abt the battery.. Did u check with a new battery installed?..
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is offline
Old 11-09-2008, 06:56 PM   #10 (permalink)
Sing Along Samsung
Tanmay Satpathy's Avatar
This may occur if a lot of programmes run in the background. I have faced such situations in my N72/N958GB.
Also check the batteries.
Win 7 and any mobile suits my MOOD
Tanmay Satpathy is offline
Old 12-09-2008, 10:20 AM   #11 (permalink)
What can be the problems from the Battery, please let me know. After i upgraded to new firmware till now my mobile has not got switched off.
Also battery i get backup of 3 days approx.
Old 12-09-2008, 10:27 AM   #12 (permalink)
Techtree Reviewer
krazzy's Avatar
Some times the battery gets a bit loose and hence looses contact with the phone causing sudden switch off. If that is the case then you can put in a small piece of, say, a paper in the battery compartment to make sure the battery stays in it's place.
Prasad Naik
krazzy is offline
Old 12-09-2008, 10:43 AM   #13 (permalink)
^ hi buddy, just checked that whether the Battery is not fit properly, the Battery is sitting fine, and there is no loss in contact.
Old 12-09-2008, 10:55 AM   #14 (permalink)
Techtree Reviewer
krazzy's Avatar
It's not something that you can see with the naked eye.
Prasad Naik
krazzy is offline
Old 12-09-2008, 11:07 AM   #15 (permalink)
Yeah i know buddy, just checked whether the battery falls, or dislocates when the Back Cover of the Mobile is removed.
Old 12-09-2008, 12:12 PM   #16 (permalink)
Techtree Reviewer
krazzy's Avatar
Since your phone is not switching off now, I guess there isn't any more problem.
Prasad Naik
krazzy is offline
Old 16-09-2008, 12:59 PM   #17 (permalink)
Daydream Believer
Ross's Avatar
Originally Posted by Tanmay Satpathy View Post
This may occur if a lot of programmes run in the background. I have faced such situations in my N72/N958GB. Also check the batteries.
I have experienced the same. FSCaller was the culprit in my case, uninstalled it and now mobile is working fine...
Originally Posted by krates View Post
^^^ well just uninstall it and then try these call softwares may be the only problem i suppose just don't use it even it takes very much ram these types of software are crap
i strongly agree..
Ross is offline
Monitor switches off automatically in Ubuntu 8.04. Help! Arun the Gr8 Open Source 8 16-06-2008 01:17 AM
IRQL_LESS...system switches off ricky_pradeep Hardware Q&A 5 22-12-2007 11:55 PM
control light switches from TV remote Bigtech Tutorials 9 12-08-2007 07:34 PM
System Switches off while Switching on the monitor Vyasram Hardware Q&A 16 05-04-2006 05:47 PM
System switches off automatically Natty Hardware Q&A 7 30-11-2005 10:42 AM
