Originally Posted by dinesh_ddt
oh ok tanx a lot..
how much does flashing cost???
Well, if you can do it yourself then it will cost you nothing. But beware flashing voids warranty. But yes, flashing is like modding...You can't go to an SE store and tell them to flash the mobile.
wat abt K530i? is it cool??
Prefer K550i...Its the best. K550i has got a much better camera.
Well, K550i is still better....Either you flash it or not...Its the best in your budget.
