LinkBack (2) Thread Tools Display Modes
Old 28-08-2008, 04:35 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
raksrules's Avatar
Default What is 2.75G EDGE Network ?
Today while going through the tech2.com website, i found this link:-
http://www.tech2.com/india/news/mobi...tember/45851/0
Here it is mentioned that Idea Cellular has 2.75G EDGE networks. I am not able to understand whats this ? I mean, does airtel also have 2.75G ?
Does it mean that i will get better internet speeds on my Nokia 6630 (which is EDGE enabled) if i am on Idea Network than on an Airtel Network ?
raksrules is offline
Old 28-08-2008, 09:55 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: What is 2.75G EDGE Network ?
IIRC EDGE is only available on 2.75G networks while 2.5G has only GPRS. So what we all are using right now is 2.75G network and Idea is not offering something special.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 29-08-2008, 01:10 AM   #3 (permalink)
Tech.Masti's Avatar
Thanks krazy for the info
OFF TOPIC:
There are also one updated EDGE, name is something like dual speed EDGE , Nokia and Siemens jointly invented it, its just a software update. This update is very less expensive, but i dont know if any telcos stared it in India
OFF TOPIC:
OK, the name of this EDGE version is DUAL CARRiER EDGE.
Tech.Masti is offline
Old 29-08-2008, 01:02 PM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
Wikipedia-2.5G
Wikipedia-2.75G
Prasad Naik
krazzy is offline
Old 29-08-2008, 10:30 PM   #5 (permalink)
As EDGE is an inch above GPRS (2.5) and it isn't even UMTS or 3G, it is classified as 2.75G. And the equipment upgrade for the Operator for getting EDGE isn't heavy over the existing GSM equipment.
Its like the same way that HSDPA is called 3.5G....Equipment upgrade over UMTS for HSDPA isn't much heavy.....
ico is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/96590-what-2-75g-edge-network.html
Thread 2.75G EDGE 覆蓋同 Peoples 比較邊個好 D? | PhoneHK 討論區 -- 全港 NO.1 手機互動平台 | Page 2 | BoardReader This thread Refback 06-06-2011 11:12 PM
Thread 2.75G EDGE 覆蓋同 Peoples 比較邊個好 D? | PhoneHK 討論區 -- 全港 NO.1 手機互動平台 | Page 3 | BoardReader This thread Refback 29-04-2011 06:24 PM
Fedora 9: Leading Edge OR Bleeding Edge Hitboxx Open Source 12 21-05-2008 01:15 PM
3G n edge sourishzzz1234 Mobiles and Tablets 2 28-06-2007 10:30 PM
Edge JohnephSi Mobiles and Tablets 9 25-06-2007 04:14 PM
What exactly is EDGE ? Dipen01 Mobiles and Tablets 7 23-07-2006 09:19 PM
What Is Edge? mandar5 Mobiles and Tablets 20 21-05-2006 02:03 PM
