28-08-2008, 01:22 PM
Tribal Boy
Mobile phone with 3G + EDGE + Wi-Fi Possible under 12K ?
OK, do not make fun of me (you are not supposed to make fun of very old people ) if this is not possible.
Requirement - Mobile phone with 3G + EDGE + Wi-Fi
No - to Nokia ! Do not ask me why, I do not like Nokia. Too much used to SE.
Is it possible to get such a mobile phone around 12K ?
If that is very low budget for the requirement, please mention whats the minimum I need to spend for the same.
Thanks in advance
[Edit]
I just saw details of HP IPAQ 512. Is it good ? Any feedback / comments ?
28-08-2008, 01:30 PM
Think Zen.
Re: Mobile phone with 3G + EDGE + Wi-Fi Possible under 12K ?
Lol @ The Old People line.
The only phone i know with those features and under that price tag is the E51, which unforturnately happens to be a Nokia.
The E51 is priced close to 12k.
Do what you will; but not because you must. -- Zen Quote
macaddict
Yes Yehi Hai Ek
www.drgauravsuneja.blogspot.com
An Apple a day keeps virus away
28-08-2008, 02:03 PM
Techans
Thanks in advance
[Edit]
Getting 3G and EDGE both on one single SE phone is an exception more than the rule.
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
28-08-2008, 02:20 PM
Although discontinued now ( AFAIK), Nokia 6630 has EDGE and 3G but no WiFi.
28-08-2008, 03:03 PM
Tribal Boy
Fast replies, thanks a lot.
OK, on a second thought, I guess 3G will take at least one year, I mean implementation. Is it correct ?
In that case, I can ignore 3G. But need EDGE and Wi-Fi
Or the same again ? I mean will not fall under 12K ?
Also, the HP IPAQ 512 shows as Rs.11750 in indiagsm. Is it a good choice ?
28-08-2008, 03:09 PM
Techans
Nokia E65
28-08-2008, 03:11 PM
Techtree Reviewer
E51 is your only choice. It is an excellent phone and no matter what you think of Nokia, once you start using this phone you'll forget everything and start liking it.
Prasad Naik
Technology Reviewer for TechTree.com
28-08-2008, 04:28 PM
Yes, Nokia E51 is your only choice if you want Wi-fi @ 12K.....
28-08-2008, 04:46 PM
Dude..U will have 2 go 4 Nokia only if u want the above mentioned features...
28-08-2008, 06:29 PM
Even I would suggest for Nokia E51 considering your requirements
28-08-2008, 06:42 PM
Rockin g33k
You want me to mention 10??
My blog-www.rayarunava.com
28-08-2008, 06:48 PM
just try using the e51 for some time before u buy buddy...i am sure you will like it
28-08-2008, 06:49 PM
Tribal Boy
Whatabout HTC Touch / HTC-S710 (I know second one cost is slightly high) or HP mobile phones ?
Anybody using those ? Any comments ?
28-08-2008, 06:59 PM
Proud to be Linux
I havent seen many SE phones around wid wifi.
BTW i bought an SE G502 two days back and its got edge and 3g.(9k wid 1gig card and sim)
http://abhinandh.com
28-08-2008, 07:58 PM
+1 for E51. Screen is a bit small though.
28-08-2008, 08:29 PM
Techtree Reviewer
Lolz. There is no EDGE in SE G502. You Phail!
Prasad Naik
28-08-2008, 08:47 PM
Krazzy it has edge but no Wifi.
+1 to E51
28-08-2008, 09:44 PM
#19 (permalink)
Techtree Reviewer
http://www.sonyericsson.com/cws/prod...02?cc=in&lc=en
That's the G502 specifications page on the Sony Ericsson website. EDGE is not mentioned there. Only UMTS and HSDPA is. Why would a company leave out something that is present on the specs page of it's own product, unless it does not exist?
Prasad Naik
28-08-2008, 09:55 PM
#20 (permalink)
Rockin g33k
http://www.gsmarena.com/sony_ericsson_g502-2350.php
It may be a typo or you are looking at a chinese version of the phone or a region specified version.
It has edge.Period.
28-08-2008, 09:58 PM
#21 (permalink)
Be CoOl rAp RuLeZ !!!
uncle get P320 asus
or
e51
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
28-08-2008, 10:20 PM
#23 (permalink)
Techtree Reviewer
Originally Posted by dreamcatcher
It was the Indian SE website. They might've forgot to specify it. In that case it is SE website PHAIL!
No more off topic posts now. Or hitboxx will ban me.
Prasad Naik
28-08-2008, 10:42 PM
#24 (permalink)
Tribal Boy
Thanks a lot for the suggestion friends. I give full respect to you and your suggestions, I am not against Nokia at all too, but I still prefer not to go for it !!! Please do not feel bad.
P320 asus looks quite promising. HTC also. Anybody in this forum use any of these ?
Yes, it seems EDGE plus Wi-Fi seems quite impossible combination for SE. At least for the models I checked in various websites.
I will check more.
28-08-2008, 11:07 PM
#25 (permalink)
Techtree Reviewer
The only SE phone that I know of which has both EDGE and wi-fi is C905, which is not yet launched and will cost more than twice your budget.
Is there any reason why you don't want to go for a Nokia phone? Cause the E51 really is perfect for you. You'd really be wasting your time searching for other phones.
Prasad Naik
28-08-2008, 11:19 PM
#26 (permalink)
Tribal Boy
@krazzy
I was using N 3230 for about 3 yrs. I used many other Nokia phones as well. I do not know the exact reason, but I am not comfortable with Nokia nowadays.
Yes, now I know getting an SE for the requirement is nearly impossible. I am thinking of increasing my budget slightly (14K) and go for Asus or HTC. But it seems not many use those ? As I couldn't see any posts regarding those.
28-08-2008, 11:45 PM
#27 (permalink)
It's true Im not confused
Get Asus P320..u wont get 3g but u get GPS...best phone in that price range..
After the game is over, the pawn and the king go into the same box
29-08-2008, 01:41 AM
#28 (permalink)
Member of Apple Family
or P527 for that matter. Superczar is selling an almost new piece in the bazaar section.
29-08-2008, 07:43 AM
#29 (permalink)
Jack of all Trades.
they both r excellant phones
my younger brother has htc touch (nice stylish phone) it now retails @ 13-14k i think
my dad owns htc s710 it has intigrated qwerty keypad(but no touch screen) it also looks gud. u can find it around 12k
hv a look at asus p320 i had ordered it thru storeguru.com for 11k nice phone n hey it has gps toooo. most probably i will get my phone today.
all of these hv wifi, gprs,edge,bluetooth n offcourse windows mobile as os
i wud suggest u asus p320 as its a new phone n has gps too
n htc s710 as ur second choice
29-08-2008, 08:20 AM
#30 (permalink)
Proud to be Linux
2 x PHAIL
I R getting edge speeds on airtel
P.S: please close your stinky mouth
