Old 20-08-2008, 04:28 PM   #1 (permalink)
AJJU
azzu's Avatar
Arrow SE application prob....
iam unable to open applications and games in my se k790i its saying application failed when iam tryin to open it.... plz help me fast
I love and Live to Design
azzu is offline
Old 20-08-2008, 05:19 PM   #2 (permalink)
raksrules's Avatar
Default Re: SE application prob....
Did the applications open before ?
If yes then try restarting the phone.
Also you can try installing a new application and see if it gets installed, if yes then try to open that.
raksrules is offline
Old 20-08-2008, 05:33 PM   #3 (permalink)
AJJU
azzu's Avatar
yes they worked all right before , i restarted the phone and even master resetted it twice but it didnt help . the whole folder named GAMES and APPLICATION is not accesible and even when i install new apps or games it given same problem plz help me guys
can any1 guide me how re-flash or update kindda think
azzu is offline
Old 20-08-2008, 05:40 PM   #4 (permalink)
Rockin g33k
dreamcatcher's Avatar
Yea, use the update manager and click on update anyway.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 20-08-2008, 09:33 PM   #5 (permalink)
AJJU
azzu's Avatar
i tried se update but my se phone is the only way i connect to net ..... so iam unable to update my sek790i thru the se update manager is there anyway i can update it thru XS++
plz help fast....
azzu is offline
Old 20-08-2008, 09:39 PM   #6 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Had the same problem.. Re-installing all apps and games worked for me..
This is not a professional approach.. But u might wanna try... Try using da pc's scandisk function...
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 20-08-2008, 09:57 PM   #7 (permalink)
AJJU
azzu's Avatar
^ iam not having the problem with the angame or app iam unable to access the whole folder . and the applications...
guys plz help
plz any 1 help
azzu is offline
Application vaibhavtek Mobiles and Tablets 6 23-11-2007 05:01 PM
Not A Win 32 Application???? readermaniax Software Q&A 9 24-02-2006 12:23 AM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
how can we check whether application is run or not in vb vikasg03 Software Q&A 2 28-10-2005 02:16 PM
win 32 application ratzee199 Software Q&A 5 08-03-2005 07:41 PM
