Old 14-08-2008, 11:26 PM   #1 (permalink)
bhunnu16's Avatar
Default Phone line busy
I am facing this problem from last 1 week. My phone line is working fine. The SNR Ratio is also good but when I try to connect it says ' Your phone line is busy' and start redialing.
Also sometime the internet light in my modem keeps on continuosly(i.e. no blinking).
I got the line checked from the exchange also but they say there is no problem from their side.
Kindly tell me solution.
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 15-08-2008, 12:00 AM   #2 (permalink)
Default Re: Phone line busy
Could be your modem has gone bad. Did you have thunderstorms with a lot of heavy lightning strikes? Are you on dial-up or broadband? Can you borrow another modem you can test with?
pimpom is offline
Old 15-08-2008, 07:46 AM   #3 (permalink)
bhunnu16's Avatar
Hi!
I have BSNL dataone 500 Plan (2.5GB limit).
Yes, its raining heavily here(Bulandshahr- U.P.(west)) from last two days.
I will be testing with other modem today and will tell you the results.
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 15-08-2008, 10:06 AM   #4 (permalink)
Sangeet Premi
2kewl's Avatar
Iam facing exactly the same problem.
2kewl is offline
Old 15-08-2008, 02:11 PM   #5 (permalink)
paroh's Avatar
This type of problem i am also facing . I am using old model of ut-300R2U.
I think the the old model is not good enough. As some time even the router window does not open
paroh is offline
Old 15-08-2008, 03:37 PM   #6 (permalink)
bhunnu16's Avatar
Well I tried connecting with other modem ( Siemens C2110) and it connected on the first click. So I guess my modem is gone .
Anyone knows if BSNL will repair or change my modem ( Siemens SL2_141). Also whether I can use any other modem ( not given by BSNL like beetel given by Airtel Broadband or any other).
Plzz help me guys.
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 15-08-2008, 06:21 PM   #7 (permalink)
just enter 192.168.1.1 in your internet explorer
enter username admin and password admin
click on advance setup
edit VPI/VCI 035
select next
select bridging..
next next next and save
save and reboot.
it will automatically reboot your modem.
when all that happen just reboot your system
and the problem will be solved..
sanju is offline
Old 15-08-2008, 08:57 PM   #8 (permalink)
bhunnu16's Avatar
Smile Re: Phone line busy
edit VPI/VCI 035
select next
select bridging..
save and reboot.
Yeppy.. My net is working now...
Thanks Sanju!
Great tip yaar. This solved my so long problem. Can you tell me what was the actual problem in my modem though my net was working till now without any change in the settings.
Thanks again
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 15-08-2008, 09:52 PM   #9 (permalink)
Those settings are like the BIOS settings of your motherboard. They can get corrupted for one reason or another. Another way to correct it is to do a master rest - again very similar to clearing the motherboard BIOS settings.
pimpom is offline
Will two ADSL routers on one phone line (in series) work? confused Hardware Q&A 13 17-05-2008 04:41 AM
Busy Mouse ra_sriniketan Software Q&A 4 15-06-2007 11:46 AM
My Cursor is always busy! emailaatif786 QnA (read only) 3 19-04-2007 07:47 PM
How can i change Line-in to Line-Out in mY AC97 Sound card? sushantvirdi Hardware Q&A 2 06-04-2007 10:56 AM
Use same phone line to connect internet same time on 2 PCs techpro_bunty Mobiles and Tablets 3 15-01-2005 12:33 AM
