Old 10-08-2008, 08:45 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Good Boy
george101's Avatar
Default i-ball 4gb pen drive WRITE PROTECTED!!!
hi guys i hav got a new problem... my new pen drive which is almost 2 week old is now showing this problem after i copy some 2gb stuff into it.. till then there is no problem but after some 2gb it says cannot sopy as disk is write protected... i tried formatting it in xp but it didnt help and i cant full format it in vista as it gets stuck after some 50%... wat shud i do????
Plz reply....... any1..........
george101 is offline
Old 11-08-2008, 01:32 PM   #2 (permalink)
Tux Fan
shaunak's Avatar
Default Re: i-ball 4gb pen drive WRITE PROTECTED!!!
Some general things I would try:
* Changing the USB port I was attaching it to, (try backpanel)
* Using the NTFS file system
* Trying it out on another computer
If these fail then the drive seems to be defective, get it replaced.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 11-08-2008, 05:29 PM   #3 (permalink)
Make sure it is not one of the chinese fake one's
sushantvirdi is offline
Old 11-08-2008, 05:35 PM   #4 (permalink)
Steady
I had similar problems with my iball pd.Its not a good buy.
Ph4x0r is offline
Old 12-08-2008, 12:04 PM   #5 (permalink)
Good Boy
george101's Avatar
its a genuine i-ball pendrive and my friend who is using transcend 8gb is also facing the same problem... wat shud i do?
Old 12-08-2008, 02:09 PM   #6 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
tell the price you bought for and it will be clear that you bought a chinese one or not :O
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 12-08-2008, 05:00 PM   #7 (permalink)
Good Boy
george101's Avatar
700rs.........
Old 12-08-2008, 07:37 PM   #8 (permalink)
Norms Buster
Try Full formatting/replace it.
VexByte is offline
Old 13-08-2008, 08:27 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
Get it replaced if its under warranty. No use struggling with it.
Cheers
Shaunak
shaunak is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/95317-i-ball-4gb-pen-drive-write-protected.html
i ball 4gb pen drive WRITE PROTECTED Mobile Monsters Question This thread Refback 17-08-2010 11:24 AM
Write Protected USB vaibhavtek Tutorials 28 22-02-2008 10:30 PM
usb write protected smslca Hardware Q&A 4 07-12-2007 06:37 PM
mmc write protected shidhin4ever Mobiles and Tablets 5 26-11-2006 09:45 AM
Drive is write protected Ablenwill Mobiles and Tablets 4 11-12-2005 05:53 PM
how to make a CD write protected????? dittualex QnA (read only) 9 15-11-2005 05:48 PM
