Old 04-08-2008, 09:50 PM   #1 (permalink)
Default hp ipaq 512 messenger
i hv an hp ipaq512 messenger......it is gprs compatible....bt the problem is that the airtel guys say tht the paticular phne is nt compatible with thm,,,,i think...if manual settings are done correctly in any device thn the gprs shld work fine..im i right???
if iam thn pls help me out with the manual settings of the phone for airtel gprs..!!
pls pls pls help..!!
thnks in advance..
manan
magneticme200 is offline
Old 04-08-2008, 10:24 PM   #2 (permalink)
Pat
Member of Apple Family
Pat's Avatar
Default Re: hp ipaq 512 messenger
It is very much possible. I remember there is one more thread on this topic in which I had replied. Search for it please.
Pat is offline
Old 04-08-2008, 11:59 PM   #3 (permalink)
buddy i found it...Configuring AirTel GPRS on Windows Mobile
bt the solution in thre doesnt work out for me..!!!
pls help.!
Old 05-08-2008, 12:28 AM   #4 (permalink)
Pat
Pat's Avatar
This is the one I was talking about. The thread shows how to configure it on ppc phone edition, but the basic idea remains the same for touch-screen phones.
NOP, Airtel Live! GPRS WORKING ON HTC S710 OR ANY OTHER WINDOWS MOBILE PHONE !!
Get the details from Customer Care (or someone from this forum) about details like APN, Proxy etc. I have been out of this scene since 8-10 months and have no idea of the current settings. Which city are you from ?
Pat is offline
Old 05-08-2008, 10:26 AM   #5 (permalink)
im from delhi only..!!
bolo bhaiyon...pls help me out..!!
Last edited by magneticme200; 05-08-2008 at 10:02 PM. Reason: Automerged Doublepost
Old 07-08-2008, 08:21 PM   #6 (permalink)
Pat
Pat's Avatar
Go to [Start]
Tap [Settings]
Tap [Connections]
Tap [Connections]
Under [My Work Network] tap [Manage Existing Connections]. If this is not present tap [Add a new modem connection]
Tap [Edit]
The [Select a Modem] drop-down box should be set to:
[Cellular Line (GPRS)]
Tap [Next]
The [Access Point Name] should be set to: airtelworld.com or airtelfun.com (not sure..confirm the Access Point Name by calling customer care)
Tap [Next]
The [Username] should be set to blank (no username)
The [Password] should be set to blank
Leave [Domain] blank
Tap [Advanced]
On the [TCP/IP] tab, only [Use Server-assigned IP Address] should be selected
Tap the [Servers] tab
Only [Use Server-assigned IP Address] should be selected
Tap [ok]
Tap [Finish]
Tap [Proxy Settings]
Tap [Advanced]
In the [WAP] field enter: 100.1.200.99
In the field to he right of this enter: 8080
In the [HTTP] field enter : 100.1.200.99
Tap [ok] 4 times and exit
Pat is offline
Old 07-08-2008, 11:38 PM   #7 (permalink)
Go to [Start]
Tap [Settings]
Tap [Connections]
Tap [Connections]
Tap [Edit]
Tap [Next]
Tap [Next]
Tap [Advanced]
Tap [ok]
Tap [Finish]
Tap [Advanced]
ill try tht mate..and thn tell ya...newys thnks fr helping..!!
regards
manan
Old 18-08-2008, 11:21 PM   #8 (permalink)
the sequence of options depicted by u here...are actually nt present there in my phne.!!
Old 19-08-2008, 12:30 AM   #9 (permalink)
Pat
Pat's Avatar
^^ It might not be exact. Come on yaar..Try to put some effort by comparing to the options on ur phone to the one in my post. It should work.
Pat is offline
Old 19-08-2008, 10:54 PM   #10 (permalink)
the problem is that i cnt get it done...by doing almst the same settings..
the same settings in perfect format i found on othr websites as well...so im sure wat u gave is perfect..and wat i did is also correct..
bt the error shown is
"The Remote Party has ended the connection."
Old 20-08-2008, 03:13 AM   #11 (permalink)
Pat
Pat's Avatar
which means that either of this is true:
a:> GPRS is not active on your connection. (Test it on some other "officially" supported phone)
or
b:> You are using the wrong apn. Confirm from customer-care which apn should you be using.
Pat is offline
Old 20-08-2008, 11:45 PM   #12 (permalink)
or
apn is?
Old 21-08-2008, 12:17 AM   #13 (permalink)
Pat
Pat's Avatar
Access Point Name
Pat is offline
ipaq 512 messenger magneticme200 Mobiles and Tablets 2 22-04-2008 09:08 AM
HP Ipaq 512 - Poor service by HP mvsaka Reviews 1 17-04-2008 08:51 AM
should i go for hp ipaq 512? tgpraveen Mobiles and Tablets 8 16-04-2008 10:19 PM
HP IPAQ 512 VOice messenger for 11,999 rs only NiluGeek Mobiles and Tablets 1 15-07-2007 01:19 AM
