Old 02-08-2008, 07:33 PM   #1 (permalink)
Default Nokia 6220 classic?
ANyone here has bought the Nokia 6220 classic? I read on the net that it feels like a cheap phone. Is this true?
If it is then too bad since I hate the N82 keypad and don't use the wi-fi in any case.
Pls can someone tell me whether its good quality build?
Confused between this phone & the E71 !!! Both look good to me !!
samman is offline
Old 02-08-2008, 09:20 PM   #2 (permalink)
clmlbx's Avatar
Default Re: Nokia 6220 classic?
classic phone have cheap build quality but are rich in features........
If u can go with that look then u should really consider that.........
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is offline
Old 02-08-2008, 10:24 PM   #3 (permalink)
Rockin g33k
dreamcatcher's Avatar
Pthetic build quality. Already keypad cracking. Better wait for the 2nd or 3rd batch of products for the problem to be solved.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 02-08-2008, 10:34 PM   #4 (permalink)
Techans
nikhilpai's Avatar
You actually bought a Nokia?
I blog at www.techans.com and tweet at @nikhilpai (Previously known as nikeel on these forums)
nikhilpai is offline
Old 02-08-2008, 10:44 PM   #5 (permalink)
Rockin g33k
Sweet dreams..
Old 02-08-2008, 10:51 PM   #6 (permalink)
Google Bot
Pathik's Avatar
get the E71.
Pathik is offline
Old 02-08-2008, 11:35 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
build quality is bad compared to N82.just try it if u can b4 u buy it.
hellgate is offline
Old 02-08-2008, 11:39 PM   #8 (permalink)
uppalpankaj's Avatar
But 6220 classic is cheaper than N82 by arnd 2k..It doesn't have Wifi..
uppalpankaj is offline
How Is Nokia 3120 classic ? clmlbx Mobiles and Tablets 18 03-10-2008 05:55 PM
Nokia 6220 classic nikhilpai Mobiles and Tablets 1 08-07-2008 11:41 PM
nokia site says nokia 3500 classic has symbian OS arunks Mobiles and Tablets 8 13-05-2008 01:41 PM
Nokia 3110 classic or 3500 Classic? abhimi Mobiles and Tablets 3 25-02-2008 05:14 PM
Help me!Nokia 6100 content copier file to restore Nokia 6220 serendipiti Mobiles and Tablets 1 14-08-2005 10:34 AM
