Old 02-08-2008, 05:51 PM   #1 (permalink)
Default Nokia 6233 3.5mm port adapter
i purchased Nokia 6233 last month and now i added a 2gb card for music.
i enquired about AD 49 adapter to connect creative ep 630 with nokia 6233 here in delhi.
it seems no body houses them .
i was shown ad 41 adapter which also has pause/play/next etc. buttons on the adapter .
will ad 41 also work with 6233.i was quoted rs.650 for the same.
anybody recently purchased ad 49 adapter plz tell its price and availability
aman2645 is offline
Old 02-08-2008, 06:34 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: Nokia 6233 3.5mm port adapter
I dnt knw about AD-41 or AD 49, But i have recently purchased a 3.5 mm adapter for my 6233 to connect Ep-630, and it cost me 45 Rs, its has a mic(useless as it is too close to the phone as the connecting wire is 3-4 inch long only) with only 1 button to change the track.
u can get one without the mic nd button for Rs 30 or less.
U can find it in any local phone accessories seller in nehru place, Palika Bazaar, Gaffar Market or Lajpat rai market (whichever is nearest to u) and price will depend on ur bargaining skills.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 02-08-2008, 06:46 PM   #3 (permalink)
thanks harryneopotter
but is this original nokia or what
how is the sound quality through ep630.is it better than default headphones that come with 6233.
if u can elaborate where you purchased it then i would be thankful to you.
also i have a doubt about incoming calls.Do we have to remove this adapter when attending a call.
aman2645 is offline
Old 02-08-2008, 10:41 PM   #4 (permalink)
its obviously not original nokia dear...I bought it from a local mobile stall at nehru place.
Now bout sound issue ..its nt as loud as the HPM 70 in sony walkman's but louder than the default handsfree of 6233 and definately much better in terms of music clarity and quality.
U can recieve calls with this adapter but the mic is very close to the handset (the adapter cable is 4 inches long, and the mic is at its end where u insert EP 630, u can imagine now)
Hope it helps.
Sachin.
Y ??
Old 03-08-2008, 11:17 AM   #5 (permalink)
Bro dont buy ad41 adaptor. It's not supported by 6233...i wasted my 600 bucks on that...
sushantvirdi is offline
Old 03-08-2008, 12:35 PM   #6 (permalink)
thanks sachin and sushant
was going to pick up ad 41 adaptor but now will find this fake adapter or search for ad 49 adapter if available anywhere
aman2645 is offline
Old 03-08-2008, 01:52 PM   #7 (permalink)
Dont get ad41...the phone will show an enhancement not supported error! Go for ad49
Old 03-08-2008, 04:29 PM   #8 (permalink)
i was searching nokia india website.i couldnt find AD 49 anywhere.maybe nokia has stopped the production of the same.
i searched for all accessories for 6233 and found out AD 46 adapter.i am sending the link of the same
http://www.nokia.co.in/link?cid=EDITORIAL_491594
any body used ad46 adapter .how is its quality and what will be its cost
aman2645 is offline
Nokia 6233 gmanog Mobiles and Tablets 81 05-03-2007 08:58 AM
Nokia 6233 or Nokia 5500 sports merawalaid Mobiles and Tablets 22 25-12-2006 12:03 PM
Nokia 6233 chits Mobiles and Tablets 6 27-09-2006 11:28 PM
Nokia 6600- IR adapter for PC captain_hook Mobiles and Tablets 6 28-02-2006 09:59 AM
Dual SIM Adapter for ny Nokia 6600 !! sidewinder Mobiles and Tablets 3 31-10-2005 06:14 PM
