Old 27-07-2008, 06:44 PM   #1 (permalink)
Red face ipod ruined!
hey guyz, one of my friend's ipod was dropped in bucket of water, it has been about 2 dayz since the incident and now the ipod opens but it acts really weird, sometimes the battery dies really quickly and sometimes song doesn't start and harddisk makes weird sounds. Does restoring the ipod fix the problem?? and btw, the screen seems to contain some water in it, how can i remove that, i have kept the ipod in the sun to dry it off but all in vein! WHAT SHOULD I SUGGEST MY FRIEND!??
pranavrahul is offline
Old 27-07-2008, 07:10 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: ipod ruined!
To send the iPod for repairing.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 27-07-2008, 09:59 PM   #3 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
+1
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 27-07-2008, 10:01 PM   #4 (permalink)
hullap's Avatar
why does this have a smiling smiley
hullap is offline
Old 28-07-2008, 12:25 AM   #5 (permalink)
+1 for sending to the repair.....
Are you talking about the Smiley of the thread??...If yes, then stands for : oops :.....Not for smiling n00b.....
ico is offline
Old 28-07-2008, 12:27 AM   #6 (permalink)
dOm1naTOr's Avatar
u shudnt have tried to start it...
it shud ve starte only after makin sure everythin has dried up completely.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 28-07-2008, 07:30 PM   #7 (permalink)
its like already, 4 dayz, and the screen is not dried yet!! WHAT SHOULD I DO?
Old 28-07-2008, 07:42 PM   #8 (permalink)
Pat
Member of Apple Family
Pat's Avatar
if you have the skills, open it up and use a hair-dryer or something to let it dry completely. Dont even try to start iPod till it is completely dry.
Pat is offline
Old 28-07-2008, 09:34 PM   #9 (permalink)
Techtree Reviewer
krazzy's Avatar
Never Ever Use A Hair Dryer To Dry Electronic Products. It'll Toast All The Ic's Inside And Make Things Even Worse. Let It Dry Naturally.
Prasad Naik
krazzy is offline
Old 28-07-2008, 10:19 PM   #10 (permalink)
Pat
Pat's Avatar
Really ? I dint know that! Infact I have successfully saved my phone using it once!
Pat is offline
Old 28-07-2008, 11:04 PM   #11 (permalink)
Techtree Reviewer
krazzy's Avatar
Then you were lucky. I've seen and heard more incidents than I can count in which a person decided to use their hair dryer to dry a wet cellphone/mp3 player and only ended up toasting up the IC's. It's better to give it to Service Centre when such things happen. I think they use Alcohol as Alcohol drives all the water out and helps it dry quickly. Then Alcohol itself being volatile dries off immediately, leaving the device dry.
Prasad Naik
krazzy is offline
Old 29-07-2008, 09:03 AM   #12 (permalink)
aryayush's Avatar
Just send it in for repair, or buy a new one, and be done with it.
aryayush is offline
iPod Video 30gb or iPod Touch ìþöŒ ? hsr Mobiles and Tablets 4 19-03-2008 03:52 AM
(to all ipod nano users)movies in ipod nano 56561 Mobiles and Tablets 3 08-01-2008 04:47 PM
Hackers Rule: iPod 5 and 5.5G Get Firmware Upgrade to iPod Classic iMav Technology News 3 16-10-2007 10:25 AM
Using Even New PCs Is Ruined by a Tangle of Trial Programs, Ads aryayush Technology News 9 02-06-2007 07:14 PM
Ipod nano OR Ipod video amol48 Mobiles and Tablets 13 11-04-2007 05:30 PM
