Old 24-07-2008, 02:49 PM   #1 (permalink)
never forgot your roots!
Exclamation vibration is not workiing in my n73...?????
heya friends ......i got a problem with my N73 .. it vibration is not working even though its enabled everyprofile ...i got checked by nokia care also but no of use....
they just cleaned the vibration device nothing else ...
tell me the solution of problem if anyone faced dat...
i also hv heard dat n73 's vibration get damaged frequently...
am waiting for ur ans....
thnxxxx
SUKHI99 is offline
Old 24-07-2008, 06:45 PM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: vibration is not workiing in my n73...?????
Reset to default settings...this may work
or
perform d 3 key procedure for hard reset
Hope 4 d best n Do d right :)
reddick is offline
Old 26-07-2008, 10:19 AM   #3 (permalink)
mad_max's Avatar
ya that happens on symbian phones i think,i'm a victim of that too but it normally gets ok after a restart.why not try the hard format like the guy above me said
mad_max is offline
How To Enable Joystick Force Feedback(Vibration) Without Drivers Harvik780 Gamerz 74 05-10-2008 01:22 PM
zebronics joystick no vibration. Help. vishnucr Gamerz 1 18-05-2008 10:21 AM
Games having Vibration Feedback ruturaj3 Gamerz 3 30-06-2007 01:16 PM
