Old 18-07-2008, 02:31 AM   #1 (permalink)
Rubik's Uncle!!
Charan's Avatar
Question Cheapest SE Phone with Bluetooth
Hello guys, I want to know which is the cheapest SE Phone which is bluetooth enabled. We used to buy K320i & K700i but its hard to find these and are running out of stock.
Please note... only SE and less than <4500. I will be buying it in bulk of 10+
Charan is offline
Old 18-07-2008, 02:38 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Cheapest SE Phone with Bluetooth
W200i, or W300i.
nd btw, y do u need 10+ low end and SE bluetooth enabled phones?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 18-07-2008, 02:49 AM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
^^^ w200i doesnot have bluetooth. and what is the cost of w300i?
regarding your query .. SE phones works best with our SMS software.
Charan is offline
Old 18-07-2008, 06:41 AM   #4 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
W300i
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 18-07-2008, 07:36 AM   #5 (permalink)
dOm1naTOr's Avatar
Its bout 4.5k I think. Also these is K530i cheaper, with slightly better cam[ 1.3], but no walkman and card slot.
W300i has vga cam, but a card slot and walkman + HPM 70.
G3: XPS M1530 |
FZ 16.
Old 18-07-2008, 07:45 AM   #6 (permalink)
sganesh's Avatar
i bougth SE w300i at 5500 rps in the month of january,It Rocks with music and Edge feature,
but Camera and design is not satisfactory.
sganesh is offline
Old 18-07-2008, 10:20 PM   #7 (permalink)
TECHNOHOLIC..............
nitansh's Avatar
Its Z530i. Another SE mobile with bluetooth is Z550i....
"You go to your TV set when you want to turn your brain off. You go to your computer when you want to turn your brain on." - STEVE JOBS
nitansh is offline
Old 19-07-2008, 11:02 AM   #8 (permalink)
w200i will fit perfectly in your budget
all are out of your budget so go for w200i
http://www.sonyericsson.com/cws/prod...overview/w200i
Give the best, Give up the rest
choicefreedom2000 is offline
Old 19-07-2008, 11:48 AM   #9 (permalink)
Rockin g33k
dreamcatcher's Avatar
W200i doesnt have bluetooth.
My blog-www.rayarunava.com
dreamcatcher is offline
Old 19-07-2008, 01:30 PM   #10 (permalink)
Well, in this budget, you should seriously consider Nokia 3110c
It has everything you need: FM, Bluetooth, Infrared, EDGE, MP3 player, Card slot & all....
You could get it for Rs.4200 (though it may vary in your area)...
Otherwise, T280& Z310 are okay. They've Bluetooth but no card slot. But I think you don't even need the card slot as K320i lacks it. Else W300i if the way to go.
ico is offline
Cheapest wi fi mobile phone? vasulic Mobiles and Tablets 1 29-11-2007 06:39 PM
Cheapest GPRS phone..... amitskale Mobiles and Tablets 15 15-04-2007 03:18 PM
Cheapest Bluetooth Edge10 Phone paid Mobiles and Tablets 1 24-12-2006 12:17 AM
Cheapest Phone with Modem desertwind Mobiles and Tablets 8 03-11-2006 11:08 AM
Cheapest Phone ? Bomb Mobiles and Tablets 14 20-09-2005 10:42 PM
