Old 16-07-2008, 08:12 PM   #1 (permalink)
UBERGEEK
PCWORM's Avatar
Unhappy Samsung cellfone Bought from Germany doesnot work...
Hi all,,,
recently one of my relatives gifted me a samsung SGH C-130 from germany...
when i tried it with my airtel card...it gives some kind of error..(invalid simcard...maybe)
is there any way i can use it here in india??
should i flash it with an indian firmware for the same model...plz help..
PCWORM is offline
Old 16-07-2008, 08:21 PM   #2 (permalink)
Default Re: Samsung cellfone Bought from Germany doesnot work...
i thnk its a branded cell....ull hav to unlock/debrand it so as to use it with other networks
manusag is offline
Old 16-07-2008, 08:24 PM   #3 (permalink)
UBERGEEK
PCWORM's Avatar
branded?? u mean those phones which are given by network providers?
PCWORM is offline
Old 16-07-2008, 08:26 PM   #4 (permalink)
Tech.Masti's Avatar
i think its locked, try to flash it with indian firmware
Tech.Masti is offline
Old 16-07-2008, 08:29 PM   #5 (permalink)
UBERGEEK
PCWORM's Avatar
Ok...ill try flashing it with an indian firware..are there any basic steps for it...coz ive never flashed any cellphone with a firmware...is there any way i can get a firmware file for my cell on the net?
PCWORM is offline
Old 16-07-2008, 08:30 PM   #6 (permalink)
yups..i thnk so...once faced d same prob with my nokia 3250...
manusag is offline
Old 16-07-2008, 08:39 PM   #7 (permalink)
UBERGEEK
PCWORM's Avatar
Wat must n done in that case?...should i flash it with an indian firmware as said by techmasti?
Thnx for the info guys!!!
PCWORM is offline
Old 16-07-2008, 08:44 PM   #8 (permalink)
donno abt flashing....but i paid rs 350 to a local shop here in mumbai to gt it unlocked
manusag is offline
Old 16-07-2008, 08:46 PM   #9 (permalink)
UBERGEEK
PCWORM's Avatar
even i tried,,,,i gave it to a samsung service centre but they told nothing can be done...
ill flash it with an indian firware..that must b the only way to make it work...
PCWORM is offline
Old 16-07-2008, 08:51 PM   #10 (permalink)
well den do try it...n post the reault here too
manusag is offline
Old 16-07-2008, 08:59 PM   #11 (permalink)
UBERGEEK
PCWORM's Avatar
yea...sure i will,,thnx 4 d info...i dunno much about flashing but will take assistance of
sum guys here...thnx once again!!
PCWORM is offline
Old 16-07-2008, 09:08 PM   #12 (permalink)
Tech.Masti's Avatar
Just go to any local mobile shop and tell them you want to unlock, they will do that , charges may vary from Rs.200-400 , i unlocked my BenQ-Siemens A38 model for Rs.200.
Old 16-07-2008, 09:16 PM   #13 (permalink)
UBERGEEK
PCWORM's Avatar
Sure,,,thanx ill try that first..!
PCWORM is offline
Old 20-07-2008, 11:54 AM   #14 (permalink)
UBERGEEK
PCWORM's Avatar
Smile Re: Samsung cellfone Bought from Germany doesnot work...
I got my phone unlocked from a local store here in poona,,thanks all ya!!
PCWORM is offline
Old 20-07-2008, 12:05 PM   #15 (permalink)
great...so how much did u paid
manusag is offline
Old 20-07-2008, 12:41 PM   #16 (permalink)
UBERGEEK
PCWORM's Avatar
i spent 500 bucks..!!
PCWORM is offline
Old 20-07-2008, 02:53 PM   #17 (permalink)
At Hell's Disq
hellgate's Avatar
try these sites.they cud solve ur prob:
http://gsmhosting.com/vbb/showthread.php?t=396479
http://www.unlock-samsung.eu/tutorial.php
hellgate is offline
My pen drive doesnot work pagol123 Hardware Q&A 8 23-03-2008 02:24 PM
Should i get the W580i from germany...? PCWORM Mobiles and Tablets 8 01-03-2008 03:17 PM
Opensuse doesnot shutdown drsethi Open Source 5 11-12-2007 06:41 PM
Suggest the best cellfone dipak15 QnA (read only) 3 06-12-2007 04:11 PM
Microsoft FAT patent fails in Germany unni Technology News 2 16-03-2007 07:50 PM
- by bhaskar
- by Soumik
