| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
The G-Axe Effect
So far, Nokia N82 suits me feature wise but not keypad & looks wise. There are some quaries which I want to clear before I go for this phone 1) Does the inbuilt GPS needs unlimited GPRS/EDGE service? I will be using the integrated GPS to find my way in Delhi, you know like going from one ally to the other or from Pragati Maidan to GK2 on my bike. Is N82 GPS usefull for such situation? N82 has many features which do look good on paper but hardly usefull in real life for mem like I don't need TV Out. It does have a 5 MP camera but I would prefer to buy G900 instead of N82 just because of the keypad & trade the 5 MP Camera. There are some things I want to clear about SE G900/G700 1) What is the video recording resolution? 2) I will be using my Idea SIM which is said to be "3G Compatible". What does that means? G900 lacks EDGE but has 3G. Right now I can pay Rs 600 a month for unlimited internet in my phone & computer with Idea. 3) Is it hard to get the touch screen repaired in case it malfunctions.? 4) Can I play WMA files & Sync with WMP11? Does it supports the MTP? Nokia N82 does this. I can live without GPS, screen rotation etc, they will hardly be used. on a 2.4" Screen the difference between 262k color & 16m color isn't much but contrast has to be high.
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com |
#2 (permalink) | |||
Fullbring
same 4 both but N82 gains upper hand...
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer |
#3 (permalink) |
Rockin g33k
1)G900 has QVGA 30fps to N82s VGA 30 fps.
2)Yea, G900 lacks EDGE, but 3G is just round the corner. Today in TOI there was a Q&A on 3G which also said that 3g will be available by the end of this month. gprs is handful enough if you want to browse pages. 3) Nopes, an SE touchscreen costs 1.5k which you are liable to pay after warranty in case of any malfunctions.SE areliable to change the screen under warranty. 4)Yes, you can play WMA files and sync with WMP11.It supports MTP. If you dont big fingers, which i guess you have
My blog-www.rayarunava.com |
#4 (permalink) |
New Gen Guru
Friend i am also in same dellima....but to tell u the truth N82 hold the upper hand in most of the things...Picture quality, voice clarity, even somewhere I read that it can record vga @ 30fps.
But lookwise I too didnt like N82...G900 is much sleeker and better looking..but then there is one more advantage of N82 i.e the softwares u can install.
Photography Gears - Nikon D3100 DSLR , Nikkor AFS VR 18-55mm , Nikkor AFS VR 55-200mm , Nikkor AF 50mm 1.8 , Nikkor AIS 55mm 2.8 Micro , Tamrac Velocity 6x Bag Yougnou YN-465 flash , Vanguard ESPOD 203AP Check my Best pics at -> http://500px.com/sujoyp |
#5 (permalink) |
Rockin g33k
Voice clarity is great in both. Picture quality, well, G900 pics are good enough.
The G900 is not yet available here.Some one please courier me one.
#6 (permalink) |
The G-Axe Effect
1) Ok, So G900 can record video in 320X240 at 30 FPS or more. This is good enough for me, if it can record at 640X480 at 15/30 fps then even better.
2) I will use Idea GPRS in the mean time & upgrade to 3G in Idea when it is available. 3) I hope I won't break the screan 4) Thanks god, that solves my lots of Audio Transfer problems. @ sujoyp We can install applications in G900 cos it is also symbian based
#7 (permalink) |
Google Bot
N82 anyday.
1) I dont know if Nokia Maps 2.0 has such detailed maps. And no you dont need GPRS except for downloading newer maps. And some times in case of A-GPS. 1) VGA at 30FPS 2) 3G has atleast one more year to come. 3) Yea. And it wont be covered under warranty if its physical damage 4) N82
My new blog: www.pathikshah.com |
#8 (permalink) |
The G-Axe Effect
@ Pathik
I like N82, feature wise it is good but more then using those feature I need a better keypad. That's the biggest reason to think of something else. 1) Thanks for clearing out that G900 makes videos at VGA resolution with 30 FPS 2) Ok, even EDGE isn't cheap either. I have net at home so the net in phone is required only when I am in Metro or traveling. For that GPRS is slow but does the work 3) Hmm....I think I will try not to break it then 4) ???? U didn't tell me weather G900 can sync with WMP11 to play WMA or not? Or just that whether it can play WMA or not in it's media player. I think I got some information but home for someone to confirm it. http://www.phonearena.com/htmls/Sony...ne-p_2593.html
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com Last edited by gxsaurav; 14-07-2008 at 12:11 PM. Reason: Automerged Doublepost |
#9 (permalink) |
Google Bot
^^ No idea about that. And Keys are no problem. You ll get used to them in a week. It is quite sad that you would reject a phone only due to its keys even when it trumps every other fone in its range.
#10 (permalink) |
Rockin g33k
WTF!!! G900 records at QVGA!!! Dont go with high expectations on this.
But the videos are good enough to watch on phone, The resolution difference really kicks in when viewed on a large screen. The G900 readily syncs with WMP and plays WMA. No concerns on this. We are taking of a phone here. If the keys are crap and it makes life difficult to type smses or make a call it cant be termed a "good" phone irrespective of the features.
My blog-www.rayarunava.com Last edited by dreamcatcher; 14-07-2008 at 12:14 PM. Reason: Automerged Doublepost |
#11 (permalink) |
The G-Axe Effect
True, Keypad is an integral part of using a phone. If Nokia can change the keypad of N82 I will buy it today only (on credit card
These particular things are clear about G900 now 1)It can play WMA Files & can sync with WMP11. Even if I buy N82 this is a feature I was going to use a lot. 2) It can record Videos either at QVGA 30 fps or VGA 30 FPS. Both are good enough for me. 3) It can play H.263, H.264 & WMV files. I love this, I have most of my files in DivX format which I can easily convert in H.264 format which I love for small screen devices. 4) It has no GPS inbuilt. I won't miss it much & can always buy the GPA enabler if I need GPS. 5) It has a 5 MP Camera with Flash, it's not like N82 but quite good enough for me as these days I m myself not getting time to make many pics. 6) Touchscreen is costly to repair. Well, phone doesn't malfunctions always, I can pay 1.5k to repair it, it's just that I wanted to know how much "time" will it take. 7) It looks better then N82 to my eyes 8) Key pad keypad keypad I would like to ask, what features does Nokia N82 has better then G900? Once I get your feedback I can decide whether I need that feature or not.
#13 (permalink) | |
Techans
#14 (permalink) |
Rockin g33k
^^Dude TRAI is pressing for a november release of 3g. International councils are putting pressure on India to accomodate this technology as 3.5g hits the market.
#15 (permalink) |
Be CoOl rAp RuLeZ !!!
ok if you can trade the cam for a better keypad then BUY N95 which is 1k more
bigger screen better GPS 3g won't be hitting india this year and for G900: has it hitted the indian stores ???
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 Last edited by krates; 14-07-2008 at 12:53 PM. Reason: Automerged Doublepost |
#16 (permalink) | |
Techans
I am actually sick & tired of reading such reports which suggest that 3G will be launched in the next 6 months in India. To be frank they are saying this for the last 2 years that it will be launched within 6 months. When I had bought my Nokia N70 about 2 years back, I wanted to make sure that I buy a 3G phone so that I can use 3G when it would launch "within 6 months" from then. Now its time to sell my N70 after just less than 2 years of usage and they still say "3G will be launched in 6 months" I wouldn't advise the N95 2 GB solely because it has only 64 MB of SD RAM. Last edited by nikhilpai; 14-07-2008 at 12:56 PM. Reason: Automerged Doublepost |
#17 (permalink) |
Rockin g33k
Nah this is for sure. Actually TRAI was into a tussle with DoT over the base 3g prices and much more.Now that TRAI has agreed to DoT's proposal we can expect a quick move into the world of 3g.
#18 (permalink) |
dude N95 rocks does not lag speed is also good no problem at all !!!
and for audiophile the dedicated audio keys simply rocks !!!
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 |
#19 (permalink) | ||
The G-Axe Effect
2) Xenon Flash is awesome, but like I said, if it is only the camera which makes N82 better then G900 then I will buy G900 instead as it trumps N82 in look & feel & keypad department. 3) EDGE...yes, this is a something where N82 excels. Even right now with my Idea SIM if I use it in my friends Nokia 5700 then I get better speeds then my phone as my phone as GPRS but his phone has EDGE too. 4) Motion Sensor...I don't think I require this. Quote:
From what my father has said (he is in BSNL at a highest post), 3G will be here in India by the end of this year. Ok, so 3G's problem is solved, what other features are there which make Nokia N82 better then G900?
#20 (permalink) |
Bayerische Motoren Werke
Gx buy G900,you will be more happy with it.We know you love SE more than nokia.
File not found. Should I fake it? (Y/N) |
#21 (permalink) | ||
Fullbring
Obviously, but dont worry u wont have 2 use a pen/pencil 2 press the keypads
True. But when compared with features looks doesn't matter, other integral parts r also very -very important Btw have u handled N82 physically Quote:
Graphics Accelerator,128MB RAM,High Grapics Games such as FIFA 2008 Well one Blasting feature u want 2 see then check this site http://symbianworld.wordpress.com/20...g900-vs-e66-w/
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer Last edited by Zangetsu; 14-07-2008 at 02:15 PM. |
#22 (permalink) |
We Both Have a Mouse!!!
hey gx,
take a look at asus P320 also, it has...... 240 x 320 pixels, 2.6 inches touch screen, 128MB ROM and 64MB RAM TI OMAP 850 (201MHz) processor, Wi-Fi 802.11b/g, edge, gprs, Microsoft Windows Mobile 6.1 Professional, Built-in GPS Windows Media Player Pocket Office (Word, Excel, PowerPoint, OneNote, PDF viewer).... only drawback is its camera -2 MP, 1600x1200 pixels, but it is autofocus... but it is priced @12990 only... worth a try... http://www.gsmarena.com/asus_p320-2347.php http://www.mobile88.com.my/mobilegal...t=41&path=40,1
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW - HP W1907 19" Wide... and Altec Lansing ATP3... |
#23 (permalink) |
Techtree Reviewer
After using the G700 I can tell that G900 UI will also be slower. Whereas N82 is a very fast phone. As far as features are concerned, N82 has a better camera, better video recording, xenon flash, 3.5mm jack, faster processor, graphics accelerator, stereo speakers, GPS, motion sensor, EDGE,3G and HSDPA, and it also supports N-Gage games. Moreover it is cheaper than G900 (19k vs 21k). G900 only has touchscreen. You'll only have to get used to the keypad. If you can achieve that then you'll have a better phone in your hand. (Btw I have also answered some of your questions in my G700 review thread).
Prasad Naik Technology Reviewer for TechTree.com |
#24 (permalink) |
Rockin g33k
aah, well please dont assess the speed of the g700 with the g900. According to esato, the latest firmware for the g900 makes it much faster.Java applications are better handled by the g900. There many hacks for UIQ, you can break into the core system and DO ANYTHING. ranging from increasing the brightness to increasing speaker volume. Flash themes,etc etc.the G900's cam is good enough and at par with the n82 in daylight. The touchscreen has more uses than you can think of. The UI is brilliant and with a few more updates, the G900 will be run like raging bull .
#25 (permalink) | ||||
The G-Axe Effect
1) NGage is for gaming, I don't play games on my mobile anyway. 2) I have already talked about the 3.5mm jack in the G700 review thread. If I use some headphone like EP-630 with Nokia N82 then I will loose the handsfree functionality as the mic will not be there in EP-630. On the other hand if I buy G900 then I can connect EP-630 to the Fast port to 3.5mm audio jack & still use it as a Mic. 3) I don't need that much memory space. I will buy a 2 GB card once & be done with it. A Rs 200 difference won't matter much. 4) G900 also has 3D Graphics accelerator with OpenGL ES Support. Like I said, it won't matter as I do not play games on my phone. 5) G900 also has 128 MB RAM. 6) Again, no gaming. Quote:
Anything else???? Both are symbian so application library is also quite big. @ nishantv2003 If U know Microsoft as much as I do, u would not be suggesting it. Windows Mobile 7 is coming in Q1 2009 due to it is not adviced to buy a Windows Mobile 6.1 based phone right now, not even xperia X1 cos it won't be upgradable to Windows Mobile 7 @ krazzy Ok, I will try getting used to the keypad. It is tough to type SMS on it with my speed though as of K750i & then the SE Looks factor is also there.
Graphics & Web Designer - SlideShare Portfolio & Blog : http://gxsaurav.com Last edited by gxsaurav; 14-07-2008 at 02:41 PM. Reason: Automerged Doublepost |
#26 (permalink) |
Well dude, G900 and C902, both are available here in Gurgaon....I had seen their boxes while I was passing by a Mobile store in a mall just day before yesterday....
G900 should be around 20.5K.... One great feature about G900 is that it has Touch Focus........Just touch the screen and camera will automatically focus at the object. This works like a charm. N82 is ~18.5K and if you can really cope up with the awkward keypad, then its okay...otherwise G900 is good....
Won't be replying to PMs for a while. Stay in touch with e-mail. Read before asking / messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
#28 (permalink) | |
and when at night you feel like listening to music plug the EP630 and listen when a call comes remove it and answer the call......... and now when every N82 feature look like crap to you buy what is in your mind why ask us you are asking like what good has N82 over G900 and everyone is telling you say i am not going to use that it is crap for me and all that so buy G900
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 Last edited by krates; 14-07-2008 at 06:29 PM. Reason: Automerged Doublepost |
#30 (permalink) |
^^ yup but he says there is no MIC
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Confusion Viewty,N82,G900,HTC Diamond | sujoyp | Mobiles and Tablets | 71 | 13-05-2009 08:06 PM |
| Need Call Recorder for Nokia N73 | satyamy | Mobiles and Tablets | 13 | 27-02-2009 02:38 AM |
| call recording software for java phone nokia 5310 | kanz | Mobiles and Tablets | 2 | 05-10-2008 09:22 PM |
| Call not allowed ! message on Nokia 6600 | Hackattack | Mobiles and Tablets | 12 | 20-09-2007 02:29 PM |
| A tough call, suggest a phone | mayurhastak | Buying Advice | 3 | 08-09-2006 01:30 PM |
