04-07-2008, 09:34 PM
respect mah authoritah!!
all purpose phone for 13-14 k
my friend needs a phone for 13k to 14k.he basically needs a all purpose phone.here's the list of his requirement(in decreasing order)
1. music:sound quality must be good.not to be too loud
2: Camera:must be a okay okay cam.
3. Big screen:must be anything greater than 2 inches
4. good looks,keypad,battery life must be great.
preferably se. the phones i have suggested are i450, w890i and w760.
please suggest any other phone (available or upcoming).
btw is w850i/w830i still available?
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
04-07-2008, 10:23 PM
Rockin g33k
Re: all purpose phone for 13-14 k
G700=Symbian+a good cam+touchscreen+good quality music @15k
Steal i say.
W760 is also a good option if you want gps.Sound quality is on the better side of handsets according to gsmarena.
My blog-www.rayarunava.com
04-07-2008, 10:28 PM
Be CoOl rAp RuLeZ !!!
for your requirements
k810i but you already own k790i then what's the need of k810i
else buy
samsung i450, w890i , N73 (but you own a N80 too then what's the need)
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
04-07-2008, 10:41 PM
It doesn't matter!
Though w890i is suits his requirements, isn't it out of your frnd budget. Better in for k810i..
04-07-2008, 11:02 PM
Rockin g33k
W890 is 13.5k.Well in his budget.
04-07-2008, 11:14 PM
It doesn't matter!
Seriously? Last time i asked i was told it was worth 15k..
04-07-2008, 11:49 PM
Rockin g33k
yep.Fell drastically last week.
05-07-2008, 12:26 AM
It doesn't matter!
Gr8... Prices on things these days are crazy..
Off-topic:
Is der any decrease in price of n81?
05-07-2008, 08:35 AM
n81 is 14k
@krates its not for me. his main priority is music.
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
05-07-2008, 08:43 AM
n81 !!
05-07-2008, 09:00 AM
Still in war with allies
Sony P1i , if u can increase your budget around 2-3 k ..it has every thing
3 G
3.2 Mp camera
PDA solution
Walkman Software for your music
Always smile in the troubled times , there will be never scarcity of smile and happiness in life , one life with many smiles ,a self made heaven
05-07-2008, 11:08 AM
if its not for you then i think you should suggest him n81
n81 is excellent for the music
2 mega pix cam is okay
good keypad and looks
wide screen and best for gaming also
in lower range w580 will also serve the purpose except the keypad
Give the best, Give up the rest
05-07-2008, 11:41 AM
But N81 has poor battery compared to K810i and N73.
G3: XPS M1530 |
FZ 16.
05-07-2008, 12:25 PM
Techtree Reviewer
Samsung i450
Prasad Naik
Technology Reviewer for TechTree.com
05-07-2008, 12:36 PM
N81 8GB has some advantages over K810i - Wi-Fi, N-Gage, 2.4inch screen, 8GB and 3.5mm jack, miniUSB
However, for K810i camera is awesome.. SE is known for good cameras with good pic quality.
05-07-2008, 02:52 PM
go and buy N81
05-07-2008, 03:10 PM
It doesn't matter!
N81 is da best phone for any tat budget then..
05-07-2008, 03:24 PM
he doesn't want a w580 as his sister has one. he is thnking about i450.its great isnt it?
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
05-07-2008, 04:21 PM
#19 (permalink)
samsung handsets are not build good in quality, My personal experience coz few of my friends are working in samsung. Even they dont suggest me to go for samsung !!
My suggestion for your budget is Nokia N81 , just called the hotspot and nokia81 is for rs14200 and nokai 81 8gb is for 15500.
Both the phones (i450 and n81 ) has the same OS " Symbian OS 9.2, Series 60 v3.1 UI " and camera is also 2 megapixel ! but for Card slot
Samsung i450
microSD (TransFlash), buy memory
- 40 MB built-in memory
N81
Card slot No
- 8 GB internal flash memory
- 96 MB SDRAM memory
- ARM 11 369 MHz processor
Also, you can compare both the phones by clicking the hyperlink mentioned below :
http://www.gsmarena.com/compare.php3...&idPhone1=2076
