Old 03-07-2008, 05:03 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Unhappy motorokr e6 freezing....please help !
I had purchased rokr 6 mnths back..but till some days back it started freezing.
when i press contacts or messages no response or very sluggish... i had done master reset still no result
done master clear also... still........same prob continues...
is there a virus in it or what ?
can somebody suggest how to resolve this hanging/freezing MOTO problem
Thanks
Sumit
esumitkumar is offline
Old 03-07-2008, 05:11 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: motorokr e6 freezing....please help !
Just get it updated to the latest firmware. That should fix the issue.
desiibond is offline
Old 03-07-2008, 05:22 PM   #3 (permalink)
Call me Sumit
can it be done @ service center or i have to that myself ?
Old 03-07-2008, 05:33 PM   #4 (permalink)
Juke Box Hero
They will do it or you can flash yourself, a cautious process but not that difficult. Just make sure you don't lose power while flashing.
If confused, then better go to a service center.
Hitboxx is offline
Old 03-07-2008, 06:04 PM   #5 (permalink)
Angootha Chaap
saurabhpatel's Avatar
Don't flash it urself if you havent done it before not when it has some problem....
get the service center to do it.
Angootha Chhaap
saurabhpatel is offline
New System Freezing.... ECE0105 Hardware Q&A 9 29-05-2008 05:02 PM
My PC is freezing frequently...help Edburg Hardware Q&A 13 28-11-2007 12:46 PM
XP freezing NIGHTMARE Software Q&A 4 03-10-2007 12:44 AM
HELP ME!!! MY PC IS FREEZING sreevirus Software Q&A 5 10-10-2004 12:47 AM
Why only games are freezing? bhalchandra Software Q&A 8 06-09-2004 07:11 PM
