hi frnds..
do the following specifications r the only tat determine the quality of a digicam photograph??
Sensor Size (inches): (ex 1/2.5" or 1/1.5") shud it be more or less??
Focal Length (35mm equivalent): (ex 38 - 114 mm)
Normal Focus Range: (ex 50 cm to Infinity
20.4 in to Infinity)
Macro Focus Range: (ex 1 cm - Infinity
0.4 in - Infinity)
Min Macro Area: (ex 31 x 23 mm
1.2 x 0.9 in)
Min Aperture: ex f/10.0
Max Aperture: ex f/3.5
Longest Shutter Time: (ex 1 or
which is best
Shortest Shutter Time: ex 1/1000
r there any more specs needed to be seen to??
..gonna buy a digicam tomoro..according to ur reply only am goin to select a piece..
