20-06-2008, 07:19 PM
It doesn't matter!
Mobile orkut
Hi everybody. I normally used to browse orkut on my sony ericsson k530i using opera 4.1. But as of today, google have introduced mobile version of orkut. Its pretty stripped down version of orkut with no eye-candy such as community, testimonials, messages etc not being supported. But i was able to browse these all in the normal version of orkut. Now i can't seem to go back to original normal version of orkut and am redirected to mobile version, which i don't like. I've tried a few things but to no avail. Does anyone know how to access normal version of orkut by bypassing the mobile version.
Hope to get answers from you guys. Thank you.
20-06-2008, 08:02 PM
Coming back to life ..
Re: Mobile orkut
Yeah .. On my cell, If I surf using Opera I get Mobile version .. But if I surf using Webkit then the default version opens allright ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
20-06-2008, 08:10 PM
It doesn't matter!
Re: Mobile orkut
Wow. Dude thx for such a quick reply. Could you tell me wer i could download the webkit.
20-06-2008, 08:35 PM
Be CoOl rAp RuLeZ !!!
Re: Mobile orkut
http://www.webkit.org/
why don't u all search google
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
20-06-2008, 08:48 PM
It doesn't matter!
Re: Mobile orkut
Thx for replying and da link..and ya i did google it to find few things such as debian webkit and other web development kit. And wudn't have asked if i knew wat i was searching exactly..
Thx for your help and link. Unfortunately webkit is for s60.. Still i got a java app named teashark which is doing the job perfectly.. Its supposed to be a java variant of webkit. So thx for the valuable piece of info.
Reason: Automerged Doublepost
20-06-2008, 11:56 PM
Re: Mobile orkut
Yupp .. Me too use Teashark .. Its a great app ... And Nokia's default browser is based on Webkit ..
21-06-2008, 07:51 AM
Re: Mobile orkut
^^ still google redirects to mobile version of google when typed google.com
21-06-2008, 08:44 PM
It doesn't matter!
Re: Mobile orkut
Google and orkut both happen to load normal versions on teashark.. Opera on other hand loads both in mobile version.
21-06-2008, 09:01 PM
You gave been GXified
Re: Mobile orkut
Saw it in train last night, good move by orkut. Opening desktop like pages used to take lots of bandwidth, at least now any more
about.me/gxsaurav
21-06-2008, 09:12 PM
It doesn't matter!
Re: Mobile orkut
Ya... Wud have been gr8 if it was done before wen there wer no powerful browser like opera mini and teashark. Now its just sad for ppl who have access to such browser on their phone. For other low-end cell-phone users though its pretty good.
Is thr Anybody who doesn't need mobile orkut on their cell phone and want to browse the normal version of orkut?
23-06-2008, 08:52 AM
Re: Mobile orkut guys plzz need ur help
guys ....i m using nokia 6600 ,just like you even i m facing tht problem of orkut mobile..even i use to surf orkut throught opera mini 4.1..
i downloaded and installed teashark.it got installed but isnt working on my cell when i open it my cell phone just hangs showing a white screen
now how will i be able to access the orkut version i m too used to plzz help me..
23-06-2008, 10:49 AM
It doesn't matter!
Re: Mobile orkut
Well here is wat u can do.. Login into da mobile version. .
In home at da very bottom thr is a help link.. Click on it.
You will be given 5 different links.. Select anyone ... In da next page thr is a option named 'contact us'. Click on it.. Then in next page select the option named 'remove transcoded page' and just fill in da form.. It takes a day or 2 for da mobile version to be deactivated...
23-06-2008, 05:17 PM
Re: Mobile orkut
man did tht,i hope it works but dude is ther any other browser like teashark??
23-06-2008, 05:28 PM
Re: Mobile orkut
Try ucweb. Download frm getjar.com
23-06-2008, 05:54 PM
Re: Mobile orkut
buddy got tht ucweb,evn hav netfrnt..but like they say aish mein jeene ki aadat hogyi lolz,man onttht opera mini orkut use to function so well tht everythng else looks cheap in frnt of it,rite nw i hv a bettr option thn ucweb,i m loging in orkut thru tspace..
i m jst hoping tht sumeet bhai's idea wrks 4 me..coz tht wud b awesum..sumeet bhai thnx so much bro..hope the plan wrks .n plz keep advicing me thru ur grt knowledge..i'll b frequently chcking updates in dis forum.
23-06-2008, 06:30 PM
It doesn't matter!
Re: Mobile orkut
Man. .thx .. Its gonna take time.. But i guess it should be fine by another day.. Ucweb wont work.. Teashark and webkit are only ones that work..since urs is a 6600 why don't u try tat once.. Link is given above..
24-06-2008, 05:45 PM
Re: Mobile orkut
sumeet bro..tht webkit is headche,wnt ther it gave me 3 webkit options 1 of arnd 25 mb, 1 of arnd 15 mb n 1 of 9 mb,i downloaded 9 mb,only 2 get a zipped file in wich ther was a folder containing 1 000 files
24-06-2008, 10:05 PM
It doesn't matter!
Re: Mobile orkut
Well its not da one for symbian then..da ones for symbian will be of 1mb atmost.. Lemme search.. I didn't download da one given above, since it was symbian .. Wat bout da orkut itself? Isn't it back to normal??
25-06-2008, 09:35 AM
#19 (permalink)
Re: Mobile orkut
I still see the mobile version even after contacting them.
25-06-2008, 10:38 AM
#20 (permalink)
Re: Mobile orkut
I used to get a 'switch to normal version' option before on opera mini 4.1
That went away few days ago - then i sued to point opera 4.1 to http://opera.com instead of m.orkut.com. the normal page would open. But im trying ti now and the frikkin 'Bad bad server; message is showing ..
You and Me forever be ...
PSpwned
25-06-2008, 10:55 AM
#21 (permalink)
Re: Mobile orkut
i dont know how, but yesterday i got a link at some site (probably operamini forum or blog) and after going through that link once, all my orkut pages are opening in desktop mode now.
good day
Amit
25-06-2008, 11:38 AM
#22 (permalink)
It doesn't matter!
Re: Mobile orkut
Like i said it takes a day or two for dem to update da entry..
K... Da bad, bad msg is coming since u r using(or ur browser is pointing at) a page which is not a part of mobile orkut..
It would be nice for others, if u wud share how it worked wit others..
25-06-2008, 01:37 PM
#24 (permalink)
It doesn't matter!
Re: Mobile orkut
Any1 still facing da problem? Try da above procedure.. Pls do tell us if it works..
I can't check da above one as my problem is already solved..
And wer is wickedbravo..? It wud be gr8 if u tell me whether da procedure i mentioned worked for u or not ....
25-06-2008, 08:06 PM
#25 (permalink)
Re: Mobile orkut
I dont think so. I was pointing to thinkdigit.com/forum - that opens normally. Compressed actually since Opera Mini does that. But orkut.com was giving some stupid problem as usual
PSpwned
25-06-2008, 09:12 PM
#26 (permalink)
Steady
Re: Mobile orkut
Teashark really worx !
26-06-2008, 12:20 AM
#27 (permalink)
It doesn't matter!
Re: Mobile orkut
Thinkdigit doesn't have a mobile version.. Tats why it loads normal page..
26-06-2008, 06:41 AM
#28 (permalink)
CBZ is better than Pulsar
Re: Mobile orkut
Yes.it works with opera also. just use 'orkut.co.in' to login n not 'orkut.com' . try it http://www.orkut.co.in/Home.aspx
26-06-2008, 10:13 AM
#29 (permalink)
It doesn't matter!
Re: Mobile orkut
Originally Posted by panacea_amc
Dis was exactly wat i did first time i got mobile orkut activated on my cell.. But it used to redirect me to m.orkut.com/home.aspx ..or show da bad bad server error message. .
26-06-2008, 11:37 AM
#30 (permalink)
Re: Mobile orkut
How come?  i m rite now browsin thru my communities thru opera mini!
