Old 18-06-2008, 06:19 PM   #1 (permalink)
Default S60 V3 doubt!!
i ws searchin 4 an app wich cud sync msgs between pc n my mob,an n73 ME;so as 2 allow me 2 format d fon memory of my mob..
actually d reason bahind my formattin is dat i can no more install selected themes wich used 2 work proply before...
id lik suggestion for both the troubles!!
thnx in advance....
~Peace ouT~
~PunK~
~PunK~ is offline
Old 19-06-2008, 10:11 AM   #2 (permalink)
Default Re: S60 V3 doubt!!
Nokia PC suite
ThinkFree is offline
Old 19-06-2008, 10:15 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
to sync msgs with pc u'll need to install Nokia PC Suite.from PC Suite select Backup and then u can backup all ur phone contents.format ur fone and then restore this backup.
wat prob r u facing when installing themes?
hellgate is offline
Old 22-06-2008, 12:18 AM   #4 (permalink)
Thumbs up Re: S60 V3 doubt!!
hmmm....
i hve tried suite....ws lukin fer sum other solution..sum 3rd party solution...
n bout d theme installation..it goes right up2 99% n then just gives an error stating unable 2 install....
thnx a mil fer all ur replies!!
~Peace ouT~
~PunK~
~PunK~ is offline
RAM Doubt guest Hardware Q&A 7 25-02-2008 01:27 PM
Ram doubt aneeshkj Hardware Q&A 4 14-04-2007 04:56 PM
one doubt please mayneu QnA (read only) 5 07-10-2006 01:05 PM
I have a doubt fibermanco QnA (read only) 8 17-09-2006 12:30 AM
A little doubt rakee QnA (read only) 6 18-04-2005 03:48 PM
