| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Last month I bought a 1GB Kingstion Micro SD card for my Nokia 3110, and I have set a password to it. But now I forgot the password, so can we any tools to unlock the MicroSD card because when I tried to access the same card in a different phone its asking for password. Thanks, Midhun. |
#3 (permalink) |
Legen-wait for it-dary!
Low level format will help, but if you want to recover the data, I dont know. Where did you set the password? and can you set a password for microsd cards?
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#5 (permalink) |
Hi All,
Thanks 4 the reply We can set the password to MicroSD card thru some Nokia phone I have searched the same on Kingston site http://www.kingston.com/support/FLASHMEMORYCARDS/mediaGeneral6.asp But apart from low level format can we have any other tools for this.. |
#6 (permalink) |
@Pathik
Can you set a password for a Memory Stick? used in Sony Ericsson. Ohkay, so did you try accessing the card via a card reader? if you can, do it, and recover the files. Then run a low level format to clear the password. Put the files back. I think that should work.
#8 (permalink) |
left this forum longback
@op: why not try your luck with mounting your phone with card on GNU/Linux?
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| unlocking please | jatt | Mobiles and Tablets | 4 | 10-02-2007 08:08 AM |
| What is Unlocking?? | khin007 | Mobiles and Tablets | 7 | 28-10-2005 01:49 PM |
| Deleting softwares from Nokia 6600 from the MMC card | Shikhar | Software Q&A | 6 | 07-05-2005 05:01 PM |
