Old 05-06-2008, 05:30 PM   #1 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Default Way to put Album art on n80 music player
I want to know how to put album art on the songs on my n80. I am wondering how to do that and I knew there should be a way...
Please help, thanks!
I'm back! Gimme a hugggggg...
cooldudie3 is offline
Old 06-06-2008, 01:32 AM   #2 (permalink)
The Techno Perv
Default Re: Way to put Album art on n80 music player
if the song has the album art embedded into it, n81 wil automatically display it.. else u hav to edit manually.. i add album arts to the songs using itunes..
dtox is offline
Old 07-06-2008, 04:53 AM   #3 (permalink)
Boom Boom Boom
cooldudie3's Avatar
How? I am talking about n80 not n81.
How should I do it manually?
Old 07-06-2008, 05:11 AM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
In Music Player, goto the song->Album art
Better download "Tag and Rename" in PC. Use it to change the album art. Now transfer these songs to the mobile. The added album art will be visible in the player
Nokia N86 8MP
Lucky_star is offline
Old 07-06-2008, 07:55 AM   #5 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
in the all songs section > select album art > options > change > select done
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 19-06-2008, 04:42 AM   #6 (permalink)
Boom Boom Boom
cooldudie3's Avatar
I don't really understand, I tried many ways but could not make it show. Can the n80 show album art?
Old 19-06-2008, 10:15 AM   #7 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
On PC, WMP has option in Advanced Tag Editor (Library) to ADD album Art into the MP3. Add the Image and then transfer it to Phone
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 19-06-2008, 10:29 AM   #8 (permalink)
Bayerische Motoren Werke
Third Eye's Avatar
Use Media monkey and auto tag from web.
File not found. Should I fake it? (Y/N)
Third Eye is offline
Old 19-06-2008, 10:39 AM   #9 (permalink)
Fullbring
Zangetsu's Avatar
^ +1 for Sukhdeep's answer....
or u can use itunes.....4 same
Windows OS Calculator Bug
Sqrt(9) - 3 = check the answer
Zangetsu is offline
Old 20-06-2008, 12:52 AM   #10 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Where is Advanced Tag Editor in WMP 11?
Old 20-06-2008, 02:01 AM   #11 (permalink)
The Devil's Advocate
iMav's Avatar
Right under your nose Right click on the file and it is the 7th option from top.
http://beingmanan.com
iMav is offline
Old 20-06-2008, 10:42 AM   #12 (permalink)
Host4Cheap.org
Click Library, Playlists, Now Playying, and then Right Click on the Song. 7th Option
Old 20-06-2008, 12:55 PM   #13 (permalink)
Power UP's Avatar
Guys even i am having the same problem with my N82
I have pin pointed the problem and it occurs only in the Mp3 files.
Files like AAC, M4a etc. show the Album art properly but not Mp3 files.
Mp3 files are normal 128Kbps CBR. (Lame 3.97,iTunes 7).
I have used all the methods iTunes,WMP and even the Nokia music manager but still no solution.
Any help for the Mp3 files
Power UP is offline
Old 21-06-2008, 12:00 AM   #14 (permalink)
Still Shining!
Lucky_star's Avatar
I am saying the same thing again. I have tried WMP, itunes, Nokia's Music Manager to add the album arts. Its working only in some files.
Use "Tag and Rename". Clear all the tags and freshly add everything including the album art. It will be visible in whatever media player or mobile you play.
Nokia N86 8MP
Old 21-06-2008, 12:20 AM   #15 (permalink)
iMav's Avatar
Guys listen if you want to embed Album Arts, the best way to do this is by embedding them in the meta info. Use mp3tag to do this.
http://www.beingmanan.com/wp/2008/05...-you-look-pro/
iMav is offline
Old 21-06-2008, 01:35 AM   #16 (permalink)
Power UP's Avatar
Thanks iMav , mp3tag works perfectly
Power UP is offline
Old 21-06-2008, 11:58 AM   #17 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Looks like MP3Tag is very useful, will download
Old 21-06-2008, 12:02 PM   #18 (permalink)
Indidiot
Plasma_Snake's Avatar
Can't we edit for Album Art in Winamp?
Plasma_Snake is offline
Old 21-06-2008, 12:11 PM   #19 (permalink)
iMav's Avatar
You can but I have faced problems like if I change the location of the song, I lose the album art. I searched a little and found that it doesn't embed the art in the meta info or something like that. Searched a bit and came across mp3Tag and have been using and recommending it to everyone and I think that is most prolly the problem posted here too.
@Power Up: glad it helped
iMav is offline
Old 21-06-2008, 09:32 PM   #20 (permalink)
Still Shining!
Lucky_star's Avatar
Yah, as iMav said, Mp3tag is also a good one.
Nokia N86 8MP
Old 22-06-2008, 08:33 AM   #21 (permalink)
Boom Boom Boom
cooldudie3's Avatar
how does mp3tag work? How do I edit the tag? On the sidebar right, please give me the instructions
Old 22-06-2008, 01:58 PM   #22 (permalink)
Power UP's Avatar
@ cooldudie3
1. Click "Change directory" to point to the folder containing your music files.
2. Click on any music file and edit its tag on the left side.
3. To add Album art , drag and drop image file to the square white box.
4. Click "Save".
Enjoy
Power UP is offline
Old 22-06-2008, 03:23 PM   #23 (permalink)
Techtree Reviewer
krazzy's Avatar
Hey doesn't N80 have the old S60 v3 player as in 3250 where the playback buttons on the screen were stacked on the left in an arc? I don't think that players displays album art, even if the song has it. Only the newer S60 player which has the playback buttons on the bottom supports album art. It'll be better if you download another music player like LCG Jukebox if you want to see album art.
krazzy is offline
Old 23-06-2008, 01:55 AM   #24 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Yep it's the old player I didn't realize it couldn't show album art
Which songs should include as background music for a marriage photo album in video cd arunks Chit-Chat 17 24-09-2007 11:53 PM
Hilary duff's Dignity music album released in UK ambandla Random News 74 19-04-2007 06:24 AM
Set ur own Album Art for Folder and Media Player amrit1 Tutorials 10 11-05-2006 04:12 PM
Music Album Info ? chitta QnA (read only) 4 19-03-2006 08:59 PM
Please design a music album cover and music album poster AMITAGARWAL02 QnA (read only) 2 23-04-2005 01:56 PM
