| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
At Hell's Disq
1>Does the firmware V20 support WMV9 playback?atleast the Nokia site claims that the video player supports WMV. 2>Does the phone hav any software probs?had faced a whole lot of probs with my N95 8GB. 3>sud i get a N78 whihc has OS9.3 FP2?other than the cam will it be a better fone that N82? 4>any chance that N96 will be available by July?
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#3 (permalink) |
At Hell's Disq
ok.so is it wise to go for the N82 or N96?
consideroing that the N96 has only DVB-H and 16GB inbuilt as xtras but looses out on the xenon flash.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] Last edited by hellgate; 05-06-2008 at 11:06 AM. Reason: Automerged Doublepost |
#4 (permalink) | |
Fullbring
if u want big memory,big screen go 4 N96 if u want awesome pic quality go 4 N82 Black Btw the price of N96 will be higher than N95 8GB But do remember 2 take a look @ user reviews on N96 coz u have mentioned ur experience with N95 8GB
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer |
#5 (permalink) |
n82 is very much like n95 8gb u have used ..same hardware .. i am using it from december without any issues .. n78 is not based on same platform as n82 ..it has single proci with no graphics accelerator and even less ram ..etc..
and even n96 is not based on same platform as n95 8gb , n82 .. so graphics acceleration is not there .. check this site .. http://thenokiaguide.typepad.com/ showing difference between n95 8gb and n96.. among few things which are lacking in n96 are xenon flash , camera lens cover , fm transmitter .. |
#6 (permalink) |
Be CoOl rAp RuLeZ !!!
dude heard from mobile-review.com
that after the release of N96 AND N78 the company will use a better symbian version for the new releases of future phones if you can wait please wait as the new symbian version will be more powerfull and can be fully customized like full screen wallpaper animated themes and much more check out google for it and N96 prices are touching skies n82 and n96 i think there will be a 10k difference
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 Previous phones: N73ME , W810I , Asus P320 |
#8 (permalink) |
Bayerische Motoren Werke
I have heard that, N96 will use the horrible n95 classic battery.
File not found. Should I fake it? (Y/N) Last edited by Third Eye; 05-06-2008 at 06:18 PM. |
#9 (permalink) |
At Hell's Disq
^^^ yup thats true.it uses a 950mAH battery.
@ krates that new Symbian platform is slated to be released by October i.e. 4 months from now and i plan to use the N82 for not more than that.and bout the price diff bet N82 & N96 doesnt concern me.i can spend bout 32k. wat bout my other queries bout WMV support and whether i sud go for N78 cuz it has a newer platform.
#10 (permalink) |
Rockin g33k
^^dont go for n78..i suggest u go for the G900..if you want to that is..on the new UIQ 3 platform and a 5 mp cam..awesum music..psp style media player...
My blog-www.rayarunava.com |
#11 (permalink) |
At Hell's Disq
^^^ is it available?wats its price?is its cam better than N82?
#12 (permalink) |
Rockin g33k
cam is not as good as the n82/k850 but its quite good..
Check here its available outside india...will be available in a week i guess..price about 19k..
#13 (permalink) |
At Hell's Disq
^^^ then i think i shall get a N82.shall be getting EDGE & GPS xtra.
and u very well know that no S60 fone is worth its salt after bout 5-6 months of use.their performance su. i think Nokia has gone completely nutts.reading everywhere in the net that N96 doesnt come with HW video acceleration and also it has dual cpu of 208MHz each (to reduce battery consumption).i mean if this tru WTF man u r bloody reducing specs of ur flagship fone?
#14 (permalink) |
Rockin g33k
Yea thats rite...but then you have to carry on with that horrible keypad...U already have the viewty for edge na??Try sumthin diff then..
and you also gain a touchscreen..and you can buy the HGE-100 gps+3.5 mm adapter to go with it...
#15 (permalink) |
At Hell's Disq
for touch screen i also hav a Samsung SGH-i710.its a 2.8" WM5 based touch screen fone.and it also has EDGE...and as far as the Viewty is concerned, my cousin is using that fone now.i dont like it that much.
#17 (permalink) |
@hellgate I am using Nokia N82 Black since couple of weeks now. It's a good phone with good speed even though it's a symbian one. As of now, I haven't accrued any sort of problem with the device. It's a perfect bundle of advanced features in todays date.
Keypad is considered to be inconvenient, however it's not as bad as its been discussed over here again and again, when you practically use it for couple of days, you will find ease of use. If you are passionate for clicking pictures/Videos, then seriously you should go for this one. Last edited by vilas_patil; 06-06-2008 at 10:51 AM. |
#18 (permalink) |
At Hell's Disq
ok.but does it play WMV.
#20 (permalink) |
^^ dude this format is supported
The N82 supports MP3, AAC, and WMA music files, including support for copy-protected WMA files
#21 (permalink) |
At Hell's Disq
^^^ i know that N82 supports WMA but i wanna know whether it supports WMV?
#25 (permalink) |
In Pursuit of "Happyness"
Install CorePlayer.. It plays everything..
Whenever you find yourself on the side of the majority, it is time to pause and reflect. - Mark Twain |
#26 (permalink) |
At Hell's Disq
^^^ i've tried core player b4 with my N95 8GB and that release didnt support WMV,cant say bout the latest version.
got the N82 Black 2day.hav only 1 complain bout the fone and its the screen brightness.it just suxx.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] Last edited by hellgate; 06-06-2008 at 11:06 PM. Reason: Automerged Doublepost |
#27 (permalink) |
wat is the use of edge in n-82
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout || Nokia N-8, Sony Ericsson C905 both rocks my world... |
#28 (permalink) |
At Hell's Disq
why do u ask that?
#30 (permalink) | |
select the light sensor and drag it to a little left Hope this helps
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| AMD's second black edition : Athlon 64 X2 5000+ Black Edition | desiibond | Reviews | 9 | 15-11-2007 05:35 PM |
| VistaVG Black: New Black Theme for Windows XP | Vishal Gupta | Random News | 29 | 14-09-2007 09:11 PM |
| screen goes black | mannu143 | QnA (read only) | 7 | 07-04-2006 07:24 AM |
| Black Out | saiaspire | QnA (read only) | 15 | 19-02-2006 07:56 PM |
| Questions...lots of questions... | Arachnid | Open Source | 16 | 15-06-2005 12:05 PM |
