Old 24-05-2008, 02:30 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default PDA's under Rs.10,000
I need your opinions on the best buy PDA's under Rs.10,000. I am in Bangalore and want to exchange one of my mobile phones Sony Ericson T-610 for it.
Charley is offline
Old 25-05-2008, 02:21 AM   #2 (permalink)
knight17's Avatar
Default Re: PDA's under Rs.10,000
I am not sure, this will help you. But try Motorokr E6 :
- http://www.gsmarena.com/motorola_rok...tures-1810.php
Here is a page from Sify Shopping
I found 2 more PDAs that you may like :
- i-Mate JAQ
- HTC P3400
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
Old 26-05-2008, 01:23 PM   #3 (permalink)
Just Do It
Charley's Avatar
Thanks for the links.
What are the specifics I should look for when buying a PDA ?
Charley is offline
Old 26-05-2008, 09:00 PM   #4 (permalink)
Google Bot
Pathik's Avatar
SE w950i, Moto Rokr e6, HTC P3400 are among the good ones.
Pathik is offline
Old 26-05-2008, 09:12 PM   #5 (permalink)
Well, the choice is upto you for deciding between a PDA or Smartfone...
Low end Windows Mobile phones suck due to poor camera and sound playback...But their mailing features are definitely better....If you want to buy a PDA, then get ready for spending atleast about 15K because cheap ones won't be worth...And you'll also have a better and more options available in the 15K category...for eg. HTC Touch
If strictly a Windows Mobile for 10K, then get P3400 as Knight17, Pathik suggested...
Else get a Symbian smartfone...Preferably N73 with a good camera for about 11K...
ico is offline
Old 26-05-2008, 10:36 PM   #6 (permalink)
Just Do It
Charley's Avatar
Do these have WiFi & 3g as well ?
Also is E51 a nice set ? The price also is under 12k.
Charley is offline
Old 26-05-2008, 10:38 PM   #7 (permalink)
Rockin g33k
dreamcatcher's Avatar
^^^^go for the E51 then..i guess it has Wifi..
My blog-www.rayarunava.com
dreamcatcher is offline
Old 26-05-2008, 11:47 PM   #8 (permalink)
Yes, E51 has Wi-fi and it has the latest Symbian OS 9.2......
ico is offline
Old 27-05-2008, 12:15 AM   #9 (permalink)
Google Bot
Pathik's Avatar
The e51 has the best features in that price but its only con is the small screen.
Pathik is offline
Old 27-05-2008, 01:07 AM   #10 (permalink)
A LOTR fan
x3060's Avatar
yes, its got small screen p3400 don't have wifi..I am using it now...I did not find any reason to move to HTCs high end models as p3400 does what I needed ... wifi was not in my list . if you need wifi then e51 is the best choice. but its small screen can be a pain..u decide.
are you really going to use wifi a lot???
buy a phone that suits your present need than looking for everything under the roof.
give a good research ,if possible get a handson on all the models and then decide..good luck
How many kilometers are there from washington Dc to Miami beach?????....;)
unban praka123!!!....
x3060 is offline
Old 27-05-2008, 03:52 PM   #11 (permalink)
Just Do It
Charley's Avatar
Regarding Wifi, I have a question. In my apartment there is a wifi spot for browsing the Net as, residents are working people. Will I be able to use that for the mobile as well.
I also would like to know about Instant Messaging, does E51 have it ?
Does this mean browsing will be very difficult? I checked other model on a website and more or less the screen sizes are similar. Correct me if I am wrong !
Ok !
Can you tell me which ones are available in this category both PDA's and Smartphones, please ?
Charley is offline
Old 27-05-2008, 07:07 PM   #12 (permalink)
Google Bot
Pathik's Avatar
In 15k, p1i and touch, e61i are the best. And dude try the e51 before you get it.
Pathik is offline
Old 27-05-2008, 07:42 PM   #13 (permalink)
Just Do It
Charley's Avatar
That E61i looks superb with all features as well.
Browsing shows (X) HTML in E51.
What kind of browser is that ? Same like IE ?
Charley is offline
Old 27-05-2008, 08:30 PM   #14 (permalink)
Yeah, for sure but only if its not password protected. If its password protected, then you need its password.
Yes, it will be difficult.......
Ok !
Now, you've a variety of options......All the fones mentioned below have Wi-fi. Some of them also are 3G but no use of 3G at present in India.
HTC Touch: http://www.gsmarena.com/htc_touch-1999.php It lacks 3G & Infrared. But it has a touchscreen....Its Windows Mobile 6...
HTC S710: http://www.gsmarena.com/htc_s710-1891.php It has both the keypads - Sliding QWERTY keyboard and the normal one. It again lacks 3G & Infrared. Its Windows Mobile 6...
Nokia E61i: http://www.gsmarena.com/nokia_e61i-1858.php This one is a complete fone with 3G. It has everything but its quite heavy if compared to others. No touchscreen though. Its Symbian.
SE P1i: http://www.gsmarena.com/sony_ericsson_p1-1982.php This is also complete like E61i but it lacks EDGE which is important in India but its 3G. It has a Touchscreen and a superior camera 3.2mp then all the others I mentioned.
ico is offline
Battle of the PDA's in my Head bruce_wayne_16 Mobiles and Tablets 9 17-10-2006 04:19 PM
