Old 20-05-2008, 01:41 AM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Question Surfing through WiFi in E51
Yeah that's my question. Whether its a Infrastructure or Ad-Hoc access point, whether its protected by WEP key or just open access, I always get the same message, "No Gateway response" What settings do I need to make for running internet on it?
Plasma_Snake is offline
Old 20-05-2008, 07:58 PM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: Surfing through WiFi in E51
Which Service provider u have?
Contact their Tech. CC Dept. n they will surely help u
Hope 4 d best n Do d right :)
reddick is offline
Old 20-05-2008, 08:22 PM   #3 (permalink)
gopz's Avatar
I use WiFi on my E51 in WEP mode without any issues. Try to reset the phone.
gopz is offline
Old 20-05-2008, 11:35 PM   #4 (permalink)
Indidiot
What do you mean by "Reset" ? Reformat?
Old 21-05-2008, 12:57 AM   #5 (permalink)
gopz's Avatar
yeah reformat . . Factory reset. But backup your data first. It should work fine if you are able to connect otherwifi devices to the same network
gopz is offline
Old 21-05-2008, 10:04 AM   #6 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
dude just tell me is that your home wifi or some service provider wifi! If its ur home wifi just open your browser and start typing some url. Once you press ok it will ask for access point.. search for wifi and thats it. If it asks for key then if its your home network then you know the key else you need to get it from the service provider!
the.kaushik is offline
Pay more for Net surfing bhavik Technology News 6 14-05-2007 07:57 PM
Surfing on pc Using K750i madmoody Mobiles and Tablets 5 13-03-2007 06:41 PM
I am going to Setup WiFi LAN (WiFi experienced user's views invited) Ricky Hardware Q&A 2 23-10-2006 06:08 PM
LINUX: surfing net choudang Open Source 6 19-11-2005 08:37 AM
