Old 17-05-2008, 09:27 AM   #1 (permalink)
Seed is the Life!!
shift's Avatar
Arrow w580 shake control
the shake control mode on my Sony Ericsson w580 is not working
ive read in other forum that it has to activated the shake control first by pressing Walkman Play Down Right Right Walkman but that too doesnt work.
firmware is default ( i e, firmware not updated nor patched)
Any other ideas????
Stupidity Causes Cancer !!
shift is offline
Old 17-05-2008, 10:31 AM   #2 (permalink)
Gracias Senor
dreams's Avatar
Default Re: w580 shake control
how do you use the shake control???
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 17-05-2008, 11:50 AM   #3 (permalink)
Google Bot
Pathik's Avatar
Do you press the Walkman button when using Shake Control??
The key combo you mentioned is used to shake without pressing the Walkman key
Pathik is offline
Old 18-05-2008, 01:45 AM   #4 (permalink)
Seed is the Life!!
shift's Avatar
Problem solved
First switch off then on. I press Walkman Play Down Right Right Play and it work. When the phone is restarted, it has to be activated again with the combo key.
Dont have any idea with the Walkman button pressed.
shift is offline
Tutorial: Flash S500 to W580 a_k_s_h_a_y Mobiles and Tablets 25 18-12-2008 05:21 PM
Shake Themes + Shake Tests on W910i - Motion Sensor at work walkmanguru Mobiles and Tablets 2 19-04-2008 09:08 PM
W580 Or 5310 ??? yogeshm.007 Mobiles and Tablets 13 10-03-2008 03:49 PM
W580, N91 or motorokr E6? PCWORM Mobiles and Tablets 15 29-02-2008 10:50 PM
!! Themes for SE W580 !! Dipen01 Mobiles and Tablets 4 28-02-2008 11:43 AM
