Old 16-05-2008, 10:51 PM   #1 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Nokia 3500c help needed
Hey guys
I am using a nokia 3500c for couple of days and am pretty satisfied with its performance but there is a problem i want u all to sort out.
The native player does not support playing ".avi" files but can play ".3gp" files. I tried installing smart movie software but alas ( i realised that the phone is not symbian ) so cant install any sis files. So please help me out to find a player that can play .avi files as well..........
signing off
thanks in advance
codename_romeo
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-05-2008, 10:29 AM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: Nokia 3500c help needed
Only Windows Mobile can directly play avi files.
Symbian can play because of the player (smart movie) and codec (need to installed separately). And there is no such codec for J2ME phone
try converting the vid u want to play to mp4
there is no too much difference with the quality
Stupidity Causes Cancer !!
shift is offline
Old 18-05-2008, 02:18 PM   #3 (permalink)
Google Bot
Pathik's Avatar
You can't play avi files. Try mp4 or 3gp.
Pathik is offline
Old 18-05-2008, 10:11 PM   #4 (permalink)
But whenever i convert file into mp4 the size of the files grows exponentially..........
a video in avi format taks 10mb
in mo4 it take 90mb
Sony Vaio CW26FG
Old 19-05-2008, 12:53 AM   #5 (permalink)
Try Converting the file to 3gp with Super Video Converter provided with this month's Digit CD/DVD. It is freeware and I am sure that you will not regret after using this software. It can also convert DAT files. Use the settings in the Screenshot below for converting to 3gp. It will also keep the filesize low and the quality will be high. Good Luck and reply me if you have any query.
cooldev007 is offline
Old 19-05-2008, 02:34 AM   #6 (permalink)
^^ Attachments not working in the forum at present.......Upload the file to some Image hosting site like: http://imageshack.us
ico is offline
Old 19-05-2008, 03:08 AM   #7 (permalink)
Tech.Masti's Avatar
convert to mp4 with low resulution
Tech.Masti is offline
Old 19-05-2008, 04:00 PM   #8 (permalink)
Thanks everyone....
I am presently using free studio manager ....but wil definitely try out Super video converter.
I had one doubt abt the camera......though it claims to be a 2 Mp camera the quality is worse than my old k510i (1.3 mp)
is there any way to enhance image quality??????? by use of any software coz i tried up all the settings possible........all are set to max
Sony Vaio CW26FG
Old 19-05-2008, 06:35 PM   #9 (permalink)
the end begins....
u cant increase quality of nokia cams. just look forgood light and get some what good picx.
sanyaldk is offline
Old 19-05-2008, 11:11 PM   #10 (permalink)
thank s everyone....... thanz for all the help
Sony Vaio CW26FG
Old 21-05-2008, 05:28 PM   #11 (permalink)
shyamno's Avatar
@ codename_romeo
How is the music quality of Nokia 3500c ? Asking bcoz im planing to have one very soon...
Visit my Blog::::::
http://shyamkol.blogspot.com
shyamno is offline
Old 22-05-2008, 09:18 PM   #12 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
install video maniac try searching on net it is built using java !!!
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 22-05-2008, 10:22 PM   #13 (permalink)
shyamno's Avatar
can't find any link of Video Maniac ..can u post some links ???
Visit my Blog::::::
shyamno is offline
Old 23-05-2008, 03:38 PM   #14 (permalink)
krates's Avatar
http://in.mobango.com/media_details/.../zkjHhZjdmv8=/
krates is offline
Old 25-05-2008, 06:35 AM   #15 (permalink)
the end begins....
music quality is ok i mean for 5000 Rs its good.
On the internet nothing is illegal, its all e-legal
sanyaldk is offline
Old 25-05-2008, 08:31 PM   #16 (permalink)
Seed is the Life!!
shift's Avatar
try using Total Video Converter........works 100%
shift is offline
Old 26-05-2008, 03:40 PM   #17 (permalink)
heartripple's Avatar
it does not support .avi format
|| Intel i5 2500k || Asus P8Z68-V ||Corsair HX 750 ||EVGA 9800 GTX || G-skill 4GB x 2 (1600 Mhz ) || WD 320+750+2TB Seagate Green || CM Scout ||
Nokia N-8, Sony Ericsson C905 both rocks my world...
heartripple is offline
Old 27-05-2008, 01:16 PM   #18 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
find out whats the format your phone supports, along with resolution. Then use SUPER and convert the video keying in the nessassary settings.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Nokia 7610: help needed. enticer86 Mobiles and Tablets 2 16-05-2008 11:44 PM
Nokia 3500c,a worthy phone??!! dhan_shh Mobiles and Tablets 33 24-02-2008 04:59 PM
===help needed!! to all NOKIA users ==== panacea_amc Mobiles and Tablets 4 03-01-2007 12:59 PM
Transfer Files from PC to Nokia 7610 - Help needed normally_crazy Mobiles and Tablets 2 22-02-2006 06:47 AM
applications needed for nokia 6600 ashishkamat Mobiles and Tablets 4 11-03-2005 08:57 PM
