Try these if helpful:
Vodafone settings:
Account Name: Vodafone_gprs
Homepage:
http://live.vodafone.in
User Name: (no need)
Pass: (no need)
Access Point Settings:
Proxy: Enabled
Proxy Address: 10.10.1.100
Proxy Port: 9401
Data Bearer: Packet Data
Bearer Settings:
Packet Data Access Point: portalnmms
Network type: IPV4
Authentication: normal
Password: (no need)
Here is the step by step process to start gprs on HTC touch
1.Call vodafone at 111 & ask them to enable gprs tell them, u r using HTC touch phone.
2.After enabling GPRS they will ask you to send an SMS as “VL to 52586?.
3.After u send this SMS u will receive a sms saying gprs settings has been send to ur mobile.
4.Now the real stuff comes, goto settings/connections/network wizard & select the country & service provider e.g India & Hutch/Vodafone & follow the instructions.
5.After doing the configuration it will ask to restart ur phone.
6.After restart goto settings/connections/connections/Advanced Tab/Select Network button
from the drop down select Hutch WAP Settings & apply.
7.Now goto Tasks tab in connections.
here u’ll see Hutch WAP Settings
Click edit my proxy server & click Advanced button.
8.here u’ll see diff proxy type & there server ip except for http which u need to add.
9.Click on HTTP & provide ip as 10.10.1.100 & port as 9401 Save the changes & u are done.
10.Open IE & njoy ur surfing…….
Start-> Settings-> Connections-> Manage Existing Connections
You Can select a new or edit the pre-existing one.
Enter The name for the connection as you like
Select the modem as Cellular line (GPRS)
Give the accesspoint name as portalnmms
Leave the username, password and domain blank.
Click on advanced and give the IP as 10.10.1.100
leave the DNS Address and click ok
and select finish.
now close the window and come back to the connections and click on edit my proxy
put a tick mark on both the check box and and give the proxy server name as 10.10.1.100 and then click on Advanced
now select HTTp and enter the server address as 10.10.1.100 and give the port number as 9401 and click ok.
Restart the phone and browse the internet.
Now for recieving the mms
Start-> Messaging-> Inbox-> Select MMS-> Menu->Tools->Options
Select the exixting one to edit or create a new account.
Leave the preferences page and move on to the servers. Select the existing one to edit or create a new one.
Server Name: mms
gateway:10.10.1.100
port number 9401
server address:
http://mms1.live.vodafone.in/mms/
connect via: the network which you have mentioned.
You can set the sending size limitation.
WAP version can be 2.0
