Old 24-04-2008, 10:58 AM   #1 (permalink)
karthi26
Posts: n/a
Default Gtalk in N82
Guy's i have N82.. Give me some idea how to get install gtalk(application that support gtalk) in my mobile.. it's good it's freeware..
Old 24-04-2008, 11:04 AM   #2 (permalink)
Ready To Rule !!!
iatb.gourav's Avatar
Default Re: Gtalk in N82
please post the above solution for my Moto Rizr Z3 also ...
Visit my hometown --> http://siliguri.co.nr !!!
iatb.gourav is offline
Old 24-04-2008, 11:10 AM   #3 (permalink)
Google Bot
Pathik's Avatar
If you are using Airtel MO or any proxy less GPRS get IMPLUS. @ gourav get Fring.
Pathik is offline
Old 24-04-2008, 02:07 PM   #4 (permalink)
dhanusaud's Avatar
I recommend LCG Slick. It's Beta, anyway it rocks.
Features:
(i) Supported protocols:
ICQ, Yahoo, AIM, MSN, Google Talk, Jabber
(ii) Text messaging
(iii) Emoticons
(iv) Alerts - sound, backlight, vibration, notify window displaying number of new messages
(v) Group and buddy management (add, delete, rename)
(vi) Message history
(vii) File transfer - send and receive files
(viii) Sending / receiving offline messages
(ix) Downloading files sent as links
For more info go to LCG Site.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 24-04-2008, 02:48 PM   #5 (permalink)
karthi26
Posts: n/a
Thank you for the help
Old 24-04-2008, 03:02 PM   #6 (permalink)
gopz's Avatar
Yes...LCG Slick is really good...try it!
gopz is offline
Old 24-04-2008, 09:00 PM   #7 (permalink)
Ready To Rule !!!
Is it free ???
I mean, I have an unlimited surfing plan (I get charged only for downloads).
So, will it cost me anything for using or sending/receiving messages from LCG ???
Old 25-04-2008, 07:12 PM   #8 (permalink)
dhanusaud's Avatar
Originally Posted by iatb.gourav View Post
Is it free ???
Ofcourse, it's free bcoz it is BETA. BETA means "Preliminary or testing stage of a software", so its free.
Messages are downloaded as well as uploaded, so you operator would charge you. In breif, you may be charged if you use any of the IMs software in Mobile, because packet data is used while sending & receiving messages, anyway it depends on your mobile operator.
Old 27-04-2008, 01:26 AM   #9 (permalink)
Wise Old Crow
blueshift's Avatar
Morange Mini
I used it in the past but nowadays couldn't login.
You must try this.
http://twitter.com/blueshift155
blueshift is offline
Old 27-04-2008, 07:24 PM   #10 (permalink)
Techans
nikhilpai's Avatar
Use ebuddy from ebuddy.com
nikhilpai is offline
Old 13-05-2008, 12:15 PM   #11 (permalink)
karthi26
Posts: n/a
I tried slick but it's not working.After setting the account i and tried to connect it's say initializing and nothing happens ... i waited for nearly half an hour but no use.
i tried palringo too but no use! can anyone help me
Old 13-05-2008, 12:23 PM   #12 (permalink)
Google Bot
Pathik's Avatar
What GPRS are you using? Does it have proxies?
Pathik is offline
Old 13-05-2008, 12:33 PM   #13 (permalink)
karthi26
Posts: n/a
I have mobile office (Airtel bangalore)
Old 13-05-2008, 12:37 PM   #14 (permalink)
Google Bot
Pathik's Avatar
Should work flawlessly then.
Pathik is offline
Old 13-05-2008, 02:52 PM   #15 (permalink)
karthi26
Posts: n/a
Do i want to change any setting in slick?
Old 13-05-2008, 04:17 PM   #16 (permalink)
dhanusaud's Avatar
nothing lot to change settings....press 0 in slick UI and set it's access point to MO. further you have to enter username & password for specific protocol...i mean Gtalk to use the chat services.
good luck..
Old 15-05-2008, 10:47 AM   #17 (permalink)
mAYHEM's Avatar
use fring
Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
http://www.speedtest.net/result/445135884.png
mAYHEM is offline
Old 15-05-2008, 01:57 PM   #18 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Use Ebuddy's mobile client .. It rocks .. Goto http://m.ebuddy.com/ on your cellphone and then download the client ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 15-05-2008, 07:02 PM   #19 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Use goTalk mobile! The Ultimate! http://www.gotalkmobile.com/
the.kaushik is offline
Gtalk crash poomullirn Software Q&A 1 04-03-2008 10:37 AM
Similies in gtalk The Conqueror Chit-Chat 5 02-12-2007 02:55 PM
gtalk on gaim blackleopard92 Open Source 18 16-06-2007 08:55 PM
gtalk & vista iMav Software Q&A 6 25-04-2007 11:34 AM
Gtalk problem... Manshahia Software Q&A 2 11-04-2007 06:07 PM
