| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Here I am providing some phone secret codes. All codes googled. Anyway, I don't take any responsibilities if you loose any of phone data, while or when trying below codes. Backup your phone data before proceeding codes like formatting phone. Some code may not respond at all, as I hv tested nokia codes in my Nokia N73ME but not tested in Nokia E51 rest codes aren't tested by me. Plz delete or close this thread if it is illegal or reposted. =============================================== NOKIA =============================================== On the main screen type *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#7370# Deep reset *#67705646# This will clear the LCD display *#0000# To view software version. *#2820# Bluetooth device address. *#746025625# Sim clock allowed status. *#62209526# - Display the MAC address of the WLAN adapter #pw+1234567890+1# Shows if sim have restrictions. *#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start) *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restart If you forgot wallet code for Nokia S60 phone, use this code reset: #7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345 Press *#3925538# to delete the contents and code of wallet. *#7328748263373738# resets security code. Default security code is 12345 Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser. =============================================== ERICSSON =============================================== On the main screen type Sony Ericsson Secret Menu: -> * <- <- * <- * (-> means press joystick, arrow keys or jogdial to the right and <- means left.) You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels. You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and vibrator tests) IMEI Number: *#06# Lockstatus: <- * * <- Shortcut to last dialed numbers: 0# Shortcut to sim numbers: On main menu type a number and press # If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press < 0000 > . < stands for left arrow button or joystick and > stands for right arrow button or joystick. =============================================== SAMSUNG =============================================== Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: *#9998*324# - *#8999*324# LCD kontrast: *#9998*523# Vibration test: *#9998*842# - *#8999*842# Alarm beeper - Ringtone test : *#9998*289# - *#8999*289# Smiley: *#9125# Software version: *#0837# Display contrast: *#0523# - *#8999*523# Battery info: *#0228# or *#8999*228# Display storage capacity: *#8999*636# Display SIM card information: *#8999*778# Show date and alarm clock: *#8999*782# The display during warning: *#8999*786# Samsung hardware version: *#8999*837# Show network information: *#8999*638# Display received channel number and received intensity: *#8999*9266# *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error LOG Menu *#8999*327# EEP Menu *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version Type in *#0000# on a Samsung A300 to reset the language Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710) Samsung E700 type *#2255# to show secret call log (not tested) Samsung A300, A800 phone unlock enter this *2767*637# Samsung V200, S100, S300 phone unlock : *2767*782257378# On the main screen type #*4773# Incremental Redundancy #*7785# Reset wakeup & RTK timer cariables/variables #*7200# Tone Generator Mute #*3888# BLUETOOTH Test mode #*7828# Task screen #*#8377466# S/W Version & H/W Version #*2562# Restarts Phone #*2565# No Blocking? General Defense. #*3353# General Defense, Code Erased. #*3837# Phone Hangs on White screen. #*3849# Restarts Phone #*7337# Restarts Phone (Resets Wap Settings) #*2886# AutoAnswer ON/OFF #*7288# GPRS Detached/Attached #*7287# GPRS Attached #*7666# White Screen #*7693# Sleep Deactivate/Activate #*2286# Databattery #*2527# GPRS switching set to (Class 4, 8, 9, 10) #*2679# Copycat feature Activa/Deactivate #*3940# External looptest 9600 bps #*4263# Handsfree mode Activate/Deactivate #*2558# Time ON #*3941# External looptest 115200 bps #*5176# L1 Sleep #*7462# SIM Phase #*7983# Voltage/Freq #*7986# Voltage #*8466# Old Time #*2255# Call Failed #*5376# DELETE ALL SMS!!!! #*6837# Official Software Version: (0003000016000702) #*2337# Permanent Registration Beep #*2474# Charging Duration #*2834# Audio Path (Handsfree) #*3270# DCS Support Activate/Deactivate #*3282# Data Activate/Deactivate #*3476# EGSM Activate/Deactivate #*3676# FORMAT FLASH VOLUME!!! #*4760# GSM Activate/Deactivate #*4864# White Screen #*7326# Accessory #*7683# Sleep variable #*3797# Blinks 3D030300 in RED #*7372# Resetting the time to DPB variables #*3273# EGPRS multislot (Class 4, 8, 9, 10) #*7722# RLC bitmap compression Activate/Deactivate #*2351# Blinks 1347E201 in RED #*2775# Switch to 2 inner speaker #*7878# FirstStartup (0=NO, 1=YES) #*3838# Blinks 3D030300 in RED #*2077# GPRS Switch #*2027# GPRS Switch #*0227# GPRS Switch #*0277# GPRS Switch #*22671# AMR REC START #*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr) #*22673# Pause REC #*22674# Resume REC #*22675# AMR Playback #*22676# AMR Stop Play #*22677# Pause Play #*22678# Resume Play #*77261# PCM Rec Req #*77262# Stop PCM Rec #*77263# PCM Playback #*77264# PCM Stop Play #*22679# AMR Get Time *#8999*364# Watchdog ON/OFF *#8999*427# WATCHDOG signal route setup *2767*3855# = Full Reset (Caution every stored data will be deleted.) *2767*2878# = Custom Reset *2767*927# = Wap Reset *2767*226372# = Camera Reset (deletes photos) *2767*688# Reset Mobile TV #7263867# = RAM Dump (On or Off) On the main screen type *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings *#7465625# = Check the phone lock status *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100) To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# . Java status code: #*53696# (Samsung X600) If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested) =============================================== MOTO =============================================== IMEI number: *#06# Code to lock keys. Press together *7 Note: [] (pause) means the * key held in until box appears. Select phone line - (use this to write things below the provider name): [] [] [] 0 0 8 [] 1 [] Add phonebook to main menu: [] [] [] 1 0 5 [] 1 [] Add messages to main menu: [] [] [] 1 0 7 [] 1 [] Copy SIM memory (phonebook menu): [] [] [] 1 0 8 [] 1 [] Eng Field options (main menu): [] [] [] 1 1 3 [] 1 [] Slow (Frequency of search menu): [] [] [] 1 0 1 [] 1 [] Medium (Frequency of search menu): [] [] [] 1 0 2 [] 1 [] Fast (Frequency of search menu): [] [] [] 1 0 3 [] 1 [] Enable EFR: [] [] [] 1 1 9 [] 1 [] Function : [] [] [] # # # [] 1 [] Change pin: [] [] [] 0 0 4 [] 1 [] Unblocking using the "puk" number: [] [] [] 0 0 5 [] 1 [] There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec. You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps: enter menu and press 048263* quickly, then you will enter the secret engineering menu under "Opcode" input 10*0*3 for GSM 900 10*0*4 for GSM 1800 10*0*5 for GSM 1900 10*0*6 for dual band GSM 900/1800 10*0*7 for dual band GSM 850/1900 To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested) =============================================== LG =============================================== LG all models test mode: Type 2945#*# on the main screen. 2945*#01*# Secret menu for LG IMEI (ALL): *#06# IMEI and SW (LG 510): *#07# Software version (LG B1200): *8375# Recount cheksum (LG B1200): *6861# Factory test (B1200): #PWR 668 Simlock menu (LG B1200): 1945#*5101# Simlock menu (LG 510W, 5200): 2945#*5101# Simlock menu (LG 7020, 7010): 2945#*70001# Simlock menu (LG 500, 600): 2947#* LG-U81XX SPECIAL CODES Code to read phone version : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'SW Ver.info' Code to reset phone : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'Factory Reset' Code to enter UNLOCK MENU : - Phone wit SIM inside - Enter 2945#*88110# Test Menu 8330 : 637664#*# Test Menu 8180 V10a: 49857465454# Test Menu 8180 V11a: 492662464663# Test Menu 8130-8138: 47328545454# Test Menu 8110-8120: 277634#*# |
#2 (permalink) |
mannuforall
This all codes are old and available anywhere in web. So Plz try for some new codes.
--- Manojr Tiwari http://www.mannuforall.in You can also contact me for any UC Browser related info. |
#5 (permalink) |
does anybody know the code for playing the radio without the headphone in Motorola's W180?
my friend's W220 allows him to do so with his code, but it does not work for the w180 googled it but without n e success |
#6 (permalink) |
@ nsbindra
Thankx for beautiful words. @ slugger I will try but don't promise. anyway u can use java app for playing online radio without headphone, which are provided there in getjar.com |
#7 (permalink) |
NP : Crysis
awesome thread dude...we all know these codes are available, obviously he didn't create them himself. its a wonderful compilation though
Gaming: Phenom II x4 965BE @ 3.6Ghz/Corsair H50 Liquid Cooling/MSI 790FX-GD70/2x2GB GSkill Ripjaws 7-7-7-24/3 x GTX 470 w/Zalman VF3000F/Corsair 850W PSU/Antec 1200/2xSpinpoint F3 500Gb RAID 0 |
#8 (permalink) |
Apple Iphone Codes ==================== *3001#12345# and tap Call. Enter field mode Field mode reveals many of the inner settings of your iphone specially up-to-date network and cell information *#06# Displays IMEI. No need to tap call IMEI is the unique identifier for your cell phone hardware together with your SIM information it identifies you to the provider network *777# and tap Call. Account balance for prepaid iPhone *225# and tap Call. Bill Balance. (Postpaid only) *646# and tap Call. Check minutes. (Postpaid only) These three are pretty self explanatory *#21# and tap call. Setting interrogation for call forwards. Discover the settings for your call forwarding. You'll see whether you have voice, data, fax, sms, sync, async, packet access, and pad access call forwarding enabled or disabled. *#30# and tap Call. Calling line presentation check. This displays whether you have enabled or disabled the presentation of the calling line, presumably the number of the party placing the call. *&76# and tap Call. Check whether the connected line presentation is enabled or not. State whether the connected line presentation is enabled or disabled. Presumably similiar to the calling line presentation. *#43# and tap Call. Determine if call waiting is enabled Displays call waiting status for voice, data, fax, sms, sync data, async data, packet access and pad access. Each item is either enabled or disabled. *#61# and tap Call. Check the number for unanswered calls. Sho the number for voice call forwarding when a call is answered. Also show the options for data, fax, sms, sync, async, packet access and pad access *#62# and tap Call. Check the number for call forwarding if no service is available. Just like the previous, except for no-service rather than no-answer situations. *#67# and tap Call. Check the number for call forwarding when the iPhone is busy. And again, but for when the iPhone is busy. *#33# and tap Call. Check for call control bars. |
#10 (permalink) |
damn busy...
Great
MSI GX660 with ATI 5870 Dell Studio 15(1555) 1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+ www.techjunkiez.com |
#12 (permalink) | ||
This will also work on S40 phones which have the wallet feature. It isn't confined only to Symbian S60s...... Anyways, thanks for this whole list....
Won't be replying to PMs for a while. Stay in touch with e-mail. Read before asking / messaging any moderator for any query: FAQ + answers for new members Read all the sticky threads before asking any type of query. Most basic questions are answered in those. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Mobile Phone Secret Codes is it works.... | sunny2585 | Chit-Chat | 1 | 25-07-2008 07:15 AM |
| SAMSUNG mobile phone codes needed. | evewin89 | Mobiles and Tablets | 2 | 09-10-2007 10:29 PM |
| Need Codes......... | Ron | QnA (read only) | 7 | 23-12-2006 12:20 AM |
| Nokia Mobile Phone Unlock & Hidden Feature codes | Orionz | Mobiles and Tablets | 10 | 07-08-2006 03:19 PM |
