| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
I don’t keep mobile only for communication, but it is a mode of entertainment for me. But I can not download DVD files in my mobile as it doesn’t support DVD files. Is there any software which can solve my problem and help me use DVD files in my mobile? Looking to get suggestions from you people!!! |
#2 (permalink) |
Asterisk enthusiast
which is your mobile ? for symbian you have many softwares which can convert and play DVD files, but you may not get the same quality as they play at 15 FPS, though there are some mobiles which can play the video files at 24-30 FPS
#3 (permalink) |
Techtree Reviewer
You cannot directly play DVD-Video files in your mobile phone. You'll have to convert it to some other format supported by your phone for it to play. You'll also have to downgrade it a bit by reducing its resolution and bitrate since mobile phones don't have enough processing power to play high resolutio/bitrate files. You can use Total Video Converter for converting your files.
Prasad Naik Technology Reviewer for TechTree.com |
#5 (permalink) |
Hi,
This is the same with everyone; it’s more than a communication device. To convert DVD files to 3GP or to mobile phone format, I am using software called Avex DVD to Mobile Video Converter Suite which manages the trouble for me. I hope that this can save you from your trouble. Good Luck!!! Last edited by david_56; 24-04-2008 at 05:23 PM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to install .jar files into mobile | k_blues24 | Mobiles and Tablets | 5 | 22-11-2006 10:45 PM |
| Trouble with media files. | ashray69 | Software Q&A | 5 | 15-08-2006 12:46 PM |
| Fedora Core 4 installed ...... trouble trouble trouble... | iinfi | Open Source | 19 | 12-10-2005 06:03 PM |
| BIG TROUBLE : Connecting mobile with PC | reddick | Mobiles and Tablets | 2 | 31-08-2005 02:30 PM |
| Video files with audio trouble | saptak | Software Q&A | 4 | 14-08-2005 02:33 AM |
