Old 11-04-2008, 05:06 PM   #1 (permalink)
Default Connect TV with two cordless headphones. How?
I want to connect the TV with two cordless headphones simultaneously. What is the best way to do it ? Is using bluetooth the way to go? Or is there any other better method? If Bluetooth is to be used, which hardware do u suggest? ie, some sort of base station and two headphones. Can u suggest some brand names? Thanx for ur time.
nsbindra is offline
Old 12-04-2008, 08:01 AM   #2 (permalink)
Default Re: Connect TV with two cordless headphones. How?
24 views and no reply !!!! Come on, guys !!!
nsbindra is offline
Old 12-04-2008, 10:23 AM   #3 (permalink)
slugger's Avatar
do those two wirelss headphones come along with a transmitter that can be attached to the audio jack?
if yes, then use an audio jack splitter to be able to attach bothe the transmitters to the telly
slugger is offline
Old 12-04-2008, 12:48 PM   #4 (permalink)
^^ I have not yet bought any hardware. I would be buying headphones (Bluetooth?? a2dp???) on all u guys advice. Come on guys!!!
nsbindra is offline
Old 12-04-2008, 01:15 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
A2DP with TV? Which TV? I'm hearing this for the first time! All the cord-less headphones I've seen are FM based and haf a small transmitter which plug into the headphone 3.5mm jack. As slugger said, get a Splitter and connect both the transmitters to it.
infra_red_dude is offline
Old 12-04-2008, 02:07 PM   #6 (permalink)
Web developer
narangz's Avatar
Even I haven't seen A2DP based headphones for TV. I've seen the FM transmitter based cordless headphones. The transmitter is plugged into the TV output 3.5 mm jack & the headphones recieve the signals from the transmitter. And if you want to use two headphone sets do as slugger suggested.
narangz is offline
Old 12-04-2008, 03:12 PM   #7 (permalink)
Won't using two fm transmitters create interference?
nsbindra is offline
Old 12-04-2008, 03:46 PM   #8 (permalink)
You'r Born Free
int86's Avatar
Get two sets of same brand, and connect just one transmitter to TV. And use both recievers simultanuosly.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 13-04-2008, 01:34 PM   #9 (permalink)
Web developer
narangz's Avatar
Well I am not sure but they might have some frequency setting.
You can also try 2 headphones on a single transmitter as suggested above by int86.
narangz is offline
Old 13-04-2008, 01:40 PM   #10 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I have seen Infrared cordless headphones here in chennai.
btw, you can try connecting a splitter to the receiver, and connecting 2 headphones to the splitter. that can work. you can find headphone splitters common in the market.
dheeraj_kumar is offline
Can we get a connector so that we can connect normal headphones to SE K 750i? ajayritik Mobiles and Tablets 25 15-03-2008 10:25 AM
Cordless Keyboard to go with G7 Sykora Hardware Q&A 8 28-07-2006 03:37 PM
Cordless Keyboard godblessedson QnA (read only) 12 25-06-2005 01:28 PM
