Re: Please help me out regarding mobile Internet
ok here v go. first of launch the pc suite, go to phone networing wizard, then go to file menu and then new connection wizard.
then select packet switched data and press next
then there will be a list of modems "installed" and "not installed"{if u get all modems as not installed then check the "show all modems" option then from there choose"sony ericsson device 125 USB WMC Modem" press next then give name{if u want other wise it will b default}
ok read it care fully in the nex window tick "use setttings from an existing entry from the phone" press next and u will get the access point names from ur phone. choose ur one {i think for airtel mobile office it is airtelgprs.com.....i think}then next and leave the username and password field blank nex and finish then press connect and u should b connected.
if not pm me
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
