Old 04-04-2008, 03:27 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Default S60 ver3 themes
Besides Carbide ui can we create themes for S60 devices using Visual Studio 2005? Also from where I can get Icon packs for S60 theme studio?
Are the icons here too are of .ico format or what?
Plasma_Snake is offline
Old 04-04-2008, 03:31 PM   #2 (permalink)
Cool G5's Avatar
Default Re: S60 ver3 themes
Google for "Icon packs", you will get many.
Resize them using Irfanview & use them in Theme studio.
Cool G5 is offline
Old 04-04-2008, 09:12 PM   #3 (permalink)
Indidiot
What's the default icon size to which they need to resized? Also any format restrictions?
Old 04-04-2008, 10:43 PM   #4 (permalink)
Cool G5's Avatar
Jpg will work just fine.
Afaik the resolution must be 128*128.
Cool G5 is offline
Old 04-04-2008, 11:59 PM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
all S60V3 phones have a minimum resolution of 240x320. So the wallpaper should be of this dimension. And the icons should be in .png or .svg format. Regarding size, it should be 32x32 or below, I think
Nokia N86 8MP
Lucky_star is offline
Old 05-04-2008, 02:09 PM   #6 (permalink)
Cool G5's Avatar
No the icons have a higher resolution than 32*32.
Yup the wallpaper must be of 240*320.
Cool G5 is offline
Old 07-04-2008, 07:38 PM   #7 (permalink)
Indidiot
How can we add the fading effect to the Active Background screen image?
Old 07-04-2008, 10:03 PM   #8 (permalink)
Still Shining!
Lucky_star's Avatar
use "theme DIY". It can be used to create the themes in the phone itself with the fading or blurring effects.
Nokia N86 8MP
Old 29-04-2008, 12:06 AM   #9 (permalink)
Indidiot
95% of the S60 ver3 themes that I pick up from the Net either give "Expired Certificate" or "Device does not supports this sis package" message. latter could be due to non backward compatibility of S60 ver 3 OS with ver2 ones but what to do Expired Certificates?
Old 29-04-2008, 11:41 AM   #10 (permalink)
dhanusaud's Avatar
go to taiebthemes.com for awesome SVGA themes for your s60v3 handheld device.
regarding "Expired Certificate" you may change your to back date (e.g. 29-04-2007) and install it.
regarding "Device does not supports this sis" the package isn't compatible for your device. to prevent this you may choose download option for your device as well.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 29-04-2008, 12:14 PM   #11 (permalink)
Cool G5's Avatar
Post Re: S60 ver3 themes
To install themes which give "Expired Certificate", just change date to 2007 & after installing again revert to 2008.
Yes & s60 v3 is not backward compatible with s60 v2.So s60 v2 softwares & themes won't install on s60 v3, thus the "Not Supported " error.
This was done to prevent viruses of s60 v2 from affecting s60 v3.
Cool G5 is offline
Old 30-04-2008, 07:28 AM   #12 (permalink)
Indidiot
First of all, WTF is "Symbian Signing"?
Second, is there any way to deconstruct or reverse engineer the theme's sis packages, i.e. be able to extract icons etc. from them.
Old 30-04-2008, 11:16 AM   #13 (permalink)
Cool G5's Avatar
Symbian Signing is to sign .sis files with a certificate.
This signing was introduced in s60 v3 for security issues.
Google for more info on the same.
Regarding reverse enginerring, I don't know.
Cool G5 is offline
Old 30-04-2008, 11:30 AM   #14 (permalink)
dhanusaud's Avatar
@Symbian Signing
It's about security issues as told by Cool G5. I mean program before being installed in your s60v3 must be passed & signed for compability as well as security issues. If not signed, program is useless.
@Decomplier
There is no software till date that would extract icons or graphics from theme installer package. There are some software (you may google), which claims they can do it but I don't believe as I have already tried three progs.
Why do you need this? Just create your own icons with photoshop or iconworkshop, resize them and upload to carbide. That's all, me too do the same.
Old 01-05-2008, 07:00 PM   #15 (permalink)
Indidiot
So How to get it "Signed"?
Secondly, WTF does it mean "Unlocking the phone", like i've E51. How duh **** do I unlock it?
Old 02-05-2008, 01:49 PM   #16 (permalink)
dhanusaud's Avatar
No need to unlock your phone, no need to get the certificate from Symbian Signed. If you wanna use your own created theme then go to www.ownskin.com, open a account there, create your own style theme with the tools provided there and install it.
^^@ WTF
GOOGLE it
If you once create theme & remove the "Theme DIY" you won't be able to remove the theme until you format da phone, as well as themes are not good, I mean they don't look as we want.
converting themes vish786 Software Q&A 5 15-11-2007 05:34 PM
From where can I get themes.... bhutanesedude Software Q&A 3 29-07-2007 09:11 PM
Themes For Windows XP BBThumbHealer Software Q&A 3 07-07-2007 03:59 PM
Themes google360beta QnA (read only) 2 22-10-2005 09:36 AM
Should Windows XP themes be included on themes section? Kiran Software Q&A 22 11-04-2004 01:12 PM
