Old 01-04-2008, 07:55 PM   #1 (permalink)
Krazy_About_Technology's Avatar
Question Sony Ericcson Phone Confusion!!
Hi Friends,
I have purchased a W660i mobile phone recently. On first 2 days, it showed network signals as raised bars. But after i enabled Vodafone GPRS settings on it, it is showing the signal bars enclosed in a blue square. On starting the phone when it starts catching signals, bars appears normally. Then in a moment the square appears, unfilled. In a moment or two it gets filled with blue color.
I have uploaded a pic of my phone screen on skydrive : Click Here
I m sorry but Its rather distorted. i have taken this using a 2 MP nokia phone camera, but still quality isn't great. But i think people with an experience with SE phones will recognize what i am trying to say.
Can anybody explain what these events mean??
Regards,
Sumit
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 01-04-2008, 08:29 PM   #2 (permalink)
Default Re: Sony Ericcson Phone Confusion!!
signal bars enclosed in a blue square means gprs is enabled in ur phone n connected.....
manusag is offline
Old 02-04-2008, 03:14 AM   #3 (permalink)
Thanks buddy for the explanation actually this is my first SE phone, previously i was using Nokia Symbian phones, but was frustrated by the sluggishness in just about every phone as well as not-up-to-the-mark sound. Now i am very happy with my SE, and found that many of the apps which i used in the symbian phones like dictionary, e-book reader, HTML browsers are also available in java version for SE phones, so absolutely no problem.
Old 02-04-2008, 02:39 PM   #4 (permalink)
mannuforall
mannuforall's Avatar
Hi!
The blue bar in square above the signal is showing your gprs status. When it filled blue it means your gprs connection is ok. When it blank it means you're not using gprs. If there's no square box it means no gprs connection or subscription.
Also you can remove it. goto connectivity menu-data comm.-preferred service and select gsm only instead of gprs & gsm. Now blue bar shown only when you connect to gprs.
mannuforall.blogspot.com
mannuforall is offline
Old 02-04-2008, 06:18 PM   #5 (permalink)
Originally Posted by mannuforall View Post
Hi!
Thanks for the tip buddy, really appreciate that
N -series or Sony Ericcson? harpoon Mobiles and Tablets 48 03-01-2007 08:27 PM
IM in sony ericcson w700i jamyang312 Mobiles and Tablets 2 24-09-2006 10:47 AM
Sony Ericcson w550i niks999 QnA (read only) 2 17-08-2006 09:48 PM
Sony Ericcson W810i shaz_21 Mobiles and Tablets 2 27-07-2006 12:40 PM
Sony ericcson W550i LegendKiller Mobiles and Tablets 3 15-04-2006 07:08 PM
