Old 30-03-2008, 11:21 PM   #1 (permalink)
hell boy
Question mp4s not playable in 6300
hi,
i tried to play mp4s in 6300 but there was only sound and the screen went black.....!!!!!!!!!! output settings:-320X136 with xvid codec and 64 kbps for audio and 192 kbps for video........ 3gps are playable but not tested for these settings is there some separate player which can play mp4s
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 31-03-2008, 01:53 AM   #2 (permalink)
Tech.Masti's Avatar
Default Re: mp4s not playable in 6300
May be some codec problem
Tech.Masti is offline
Old 31-03-2008, 07:54 AM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
XVid won't work on 6300. You can only play videos in 3gp and mp4 format.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 31-03-2008, 09:05 AM   #4 (permalink)
hell boy
^^xvid was used and mp4 was the container these files are perfectly playable on n73..........!!!!
Old 31-03-2008, 09:41 AM   #5 (permalink)
Techtree Reviewer
krazzy's Avatar
^^ Even N73 doesn't support XVID natively. You'd have most probably used it in a 3rd party software like smartmovie, etc. Since you cannot install these softwares in 6300, I guess you have no choice but to convert your files in 3gp or mp4 (the converted files should have either of these two extensions.)
Prasad Naik
krazzy is offline
Old 12-11-2009, 06:14 PM   #6 (permalink)
dude ur problem is relating to frame rate of ur video.
convert video with 15fps.
try to use alive or xilisoft mp4 converter
jkpatel8 is offline
CRYSIS Demo is playable on Intel Onboard X3000 [G965 MB] yesh1683 Gamerz 46 07-11-2007 11:08 AM
how to write a dvd playable on dvd player from data written by nero vision arunks Software Q&A 5 16-09-2007 12:47 AM
Halo 2 for VISTA is playable on Intel GMA X3000 yesh1683 Gamerz 18 01-06-2007 01:22 PM
saved mpg file of vcd cutter not playable Ramakrishnan QnA (read only) 5 15-05-2006 11:23 AM
Video spitting software so that the parts are playable? rachitar Software Q&A 9 16-06-2005 12:31 PM
