Old 27-03-2008, 12:48 PM   #1 (permalink)
karthi26
Posts: n/a
Default Vibrator is not working in N82
hello guy's i found that my vibrator is not working yesterday only i bought can anyone help me!
Old 27-03-2008, 01:42 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Vibrator is not working in N82
Your use and description of the word vibrator^ sounds misleading. If its brand new and you are not able to enable vibration mode as per the manual take it back to the dealer and demand a replacement. If he refuses or offers a repair instead, consult your local consumer body on further course of action.
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 27-03-2008, 05:36 PM   #3 (permalink)
Techtree Reviewer
krazzy's Avatar
Did you check it while charging the phone? Cause in Nokia phones the vibrator does not work while the phone is charging. Also it is disabled by default. Go to profiles and turn it ON and then select that profile. If it still doesn't work, then send it for repairs.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 27-03-2008, 05:54 PM   #4 (permalink)
karthi26
Posts: n/a
I turned off and switched on now it's working! so do i want to still check?
Old 27-03-2008, 07:13 PM   #5 (permalink)
Correct.
ThinkFree is offline
Not working well kumarn_2004 QnA (read only) 3 13-03-2007 06:16 PM
Pc not working Cool G5 Hardware Q&A 11 01-01-2007 07:03 PM
** Working/Not-Working Programs with VISTA ** PrinceHeart Software Q&A 42 01-10-2006 04:01 PM
Vibrator ! ! ! ax3 Mobiles and Tablets 14 13-02-2006 07:24 AM
dvd rom not working Jitendra_gamer QnA (read only) 3 07-05-2005 11:20 AM
