ShureSE530PTH Sound Isolating Earphones. Price: $550.
Key Features:
The SE530 and SE530PTH mark the bridge from the classic E Series line, to the new line of Sound Isolating Earphones from Shure (SE Models). Evolved from personal monitor technology road-tested by pro musicians and fine-tuned by Shure engineers, the SE530PTH and SE530 earphones deliver unparalleled acoustic accuracy. Triple TruAcoustic MicroSpeakers, one tweeter and dual woofers, deliver an expansive sound stage with full-bodied bass—for an auditory experience rivaled only by live performances.
Sound Isolating Design
Included
sound isolating sleeves block over 90 percent of ambient noise. Combined with a low-profile ergonomic design and modular cable options, interruptions from the outside world are minimized—so you can focus on your passion. On occasions when you must tear yourself away from the music, the Push-To-Hear Control included with the SE530PTH activates a VoicePort(TM) microphone, allowing conversation without removing your earphones. Shure Sound Isolating Earphones
require a proper fit to achieve the best sound.
Optimized for listening to high-quality recordings and lossless formats, the SE530PTH utilizes three balanced armature drivers—one dedicated tweeter and dual woofers. Additionally, integrated passive crossovers ensure that high and low frequencies remain distinct and defined. The result is an incredibly wide and detailed soundstage, distinguished by precision highs and robust bass. This innovative triple driver configuration is first in class for universal fit, sound isolating earphones.
Push-To-Hear Control (included with SE530PTH)
A first for sound isolating earphones, the detachable Push-To-Hear Control allows you to activate the VoicePortTM microphone and adjust levels of external sound for clarity—ideal for brief conversations without removing your earphones. The switch allows you to conveniently alternate between your music and your connection to the outside world.
Similar to the microphones used in Shure QuietSpot® cellular headsets, the VoicePort microphone is tuned to pick up the human voice, ensuring maximum intelligibility. Included with the SE530PTH, it is available as an optional accessory for all Shure Sound Isolating Earphone models, including the SE210, SE310 and SE420.
Premium Fit Kit Includes:
Sound Isolating Sleeves
The role of the included sound isolating sleeves is twofold: blocking ambient noise and ensuring customized fit and comfort. Because every ear is different, the Premium Fit Kit includes three sizes (S, M, L) of the Flex and Black Foam Sleeves as well as a pair of universal-fit Triple Flange Sleeves. Experiment with the size and style that creates the best fit for you—a good seal is key to optimizing sound isolation and bass response as well as maximizing comfort during extended wear.
Modular Cable
Based on extensive user feedback, Shure engineers have developed a detachable cable solution to enable unmatched personal customization. An included 3-foot cable (91 cm) and 9” cable (23 cm) allows you to tailor your experience depending on activity and application.
In addition to the sound isolating sleeves and modular cables, the premium accessories kit includes:
- ¼” Adapter
Offers a solution for home stereos or other applications with ¼" jacks
- Carrying Case
Provides a convenient, tangle-free solution to store your earphones
- Level Attenuator
Allows for comfortable listening from any high-output audio source, including airplane armrests
- Airline Adapter
Optimizes compatibility with European airplane armrests
Two-Year Limited Warranty
Every SE530/SE530PTH purchased comes with a two-year limited warranty on materials and workmanship. (See
warranty information)
http://www.shure.com/PersonalAudio/P..._se530_content
