Old 23-03-2008, 02:54 PM   #1 (permalink)
respect mah authoritah!!
girish.g's Avatar
Default hpm-70
today i bought a hpm-70 as my previous hpm-70's fast port has broken.
bought it for 700rs. it has a remote control to change traks just like hpm-82.
how do i know it is original. i got the original packing with it.
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
girish.g is offline
Old 23-03-2008, 03:03 PM   #2 (permalink)
Stalker's Avatar
Default Re: hpm-70
AFAIK, HPM-70 doesnt have any control to change tracks.
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 23-03-2008, 03:06 PM   #3 (permalink)
girish.g's Avatar
Default Re: hpm-70
i know that
but now i have two hpm 70 one with the control and other without controls
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
girish.g is offline
Old 24-03-2008, 11:35 AM   #4 (permalink)
Point Blanc
Default Re: hpm-70
how you know you bought HPM 70, you may have bought HPM-82, heehe
acewin is offline
Old 24-03-2008, 02:11 PM   #5 (permalink)
girish.g's Avatar
Default Re: hpm-70
i have seen hpm-82. and this looks completely different.
it came in the original box with hpm-70 written on it
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
girish.g is offline
Old 24-03-2008, 03:55 PM   #6 (permalink)
Default Re: hpm-70
Would be better if you had bought ep-630.
Oh $hit!
Head Banger is offline
Old 25-03-2008, 07:22 PM   #7 (permalink)
girish.g's Avatar
Default Re: hpm-70
i know but i needed the 3.5mm adaptor
HP DV6 1319tx
N82 8GB(black)
Jabra BT3030
girish.g is offline
Old 29-03-2008, 06:16 PM   #8 (permalink)
Point Blanc
Default Re: hpm-70
nyways alls good if it ends well, if you fast port is working good then the remote is just addon I will say. Though I also wanted fastport similar, but didnt get. nyways I will try a new one only after my current gets wasted.
acewin is offline
