Old 17-03-2008, 10:37 AM   #1 (permalink)
dhanusaud's Avatar
Default Cleaner
Is there anyway or any software that we could clean temporary files & invalid registries in S60 V3 & S60 V2?
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 17-03-2008, 11:40 AM   #2 (permalink)
Cool G5's Avatar
Default Re: Cleaner
AFAIk there are none.
I mostly manually clen these files.
Also reboot your device once in a day,to clear unwanted files & free up your RAM.
Cool G5 is offline
Old 17-03-2008, 12:07 PM   #3 (permalink)
dhanusaud's Avatar
Default Re: Cleaner
Tanks a lot, I wanna clear cache, I mean da same files which were stored in my phone while surfing da web.
Old 17-03-2008, 05:09 PM   #4 (permalink)
Cool G5's Avatar
Default Re: Cleaner
^U can clear them via options>Clear private data>Clear cache.
If you want to delete all cookies & saved passwords,then hit "All".
Cool G5 is offline
Old 17-03-2008, 06:04 PM   #5 (permalink)
dhanusaud's Avatar
Default Re: Cleaner
Tks a lot.
Computer Cleaner BULLZI Hardware Q&A 7 24-12-2007 04:40 PM
PC-Cleaner registry cleaner to fix your errors systemcleaner QnA (read only) 6 09-03-2007 06:34 PM
Which Registry Cleaner is the best ? ranaknight Software Q&A 14 29-11-2006 05:11 PM
CD cleaner - Rs 80 ok or not ? reddragon Hardware Q&A 5 23-08-2006 03:30 AM
After using ATF Cleaner saiaspire QnA (read only) 2 04-06-2006 05:36 PM
